Aller au contenu principal
DeWalt DW920 Rotational Switch Replacement
Ce dont vous avez besoin
  1. DeWalt DW920 Rotational Switch Replacement, Disassembly: étape 1, image 1 de 1
    • Using an H-5.0 bit driver remove the four T-10 Torx screws.
  2. DeWalt DW920 Rotational Switch Replacement: étape 2, image 1 de 1
    • Use 2 H-5.0 bit drivers to take out the main bolt and head.
    • There will be blue locktite on the tread.
  3. DeWalt DW920 Rotational Switch Replacement: étape 3, image 1 de 1
    • Carefully remove the two halves of the handle.
  4. DeWalt DW920 Rotational Switch Replacement, Rotational Switch: étape 4, image 1 de 1
    • Locate the rotational switch
  5. DeWalt DW920 Rotational Switch Replacement: étape 5, image 1 de 1
    • Carefully release the connection between the rotational switch and the motor assembly. This should be done carefully to ensure that the switch connection switch on the assembly is not damaged.
  6. DeWalt DW920 Rotational Switch Replacement: étape 6, image 1 de 1
    • Once the switch is freed from the assembly, firmly grip it between two fingers and lift it straight out of the drill frame.
Cameron MacKinnon
Membre depuis le 04/06/16
241 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 8-2, Botvin Spring 2016 Membre de l'équipe UMass Dartmouth, Team 8-2, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G2
2 membres
6 tutoriels rédigés
Un commentaire
Everything looks good on this guide, good job!
DankMemerino - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 12
Total : 1,373
