Aller au contenu principal
DeWalt DW936 Boot Replacement
Ce dont vous avez besoin
  1. DeWalt DW936 Boot Replacement, Plastic Cover: étape 1, image 1 de 1
    • Use a T-20 hexhead screw to unscrew 4 hexagonal screws surrounding the base of the black air filter. The screws are on the yellow portion.
  2. DeWalt DW936 Boot Replacement: étape 2, image 1 de 1
    • Use a T-15 hexhead screw to unscrew 5 hexagonal screws. These screws are located on the opposite side of the saw from previous step.
  3. DeWalt DW936 Boot Replacement: étape 3, image 1 de 1
    • Remove Allen Key.
  4. DeWalt DW936 Boot Replacement: étape 4, image 1 de 1
    • Unscrew the black plastic knob underneath the trigger.
  5. DeWalt DW936 Boot Replacement: étape 5, image 1 de 1
    • Grab hold of the black air filter portion and pull off.
  6. DeWalt DW936 Boot Replacement: étape 6, image 1 de 1
    • This is what the inside of the saw looks like.
  7. DeWalt DW936 Boot Replacement, Boot: étape 7, image 1 de 1
    • Use a T-15 hex head screw to unscrew the four screws located around the outside of the motor.
  8. DeWalt DW936 Boot Replacement: étape 8, image 1 de 1
    • Using an H 4.0 hex head screw, unscrew the bolt located right above the boot that is next to the motor of the saw.
  9. DeWalt DW936 Boot Replacement: étape 9, image 1 de 1
    • Pull the blade away from the body of the saw causing the blade and boot to detach.
  10. DeWalt DW936 Boot Replacement: étape 10, image 1 de 1
    • Pull the boot downwards away from the blade to detach it.
Scott Weinhardt
Membre depuis le 01/25/17
603 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 8-2, Banghart Winter 2017 Membre de l'équipe Cal Poly, Team 8-2, Banghart Winter 2017
CPSU-BANGHART-W17S8G2
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 13
Total : 486
