Aller au contenu principal
DeWalt DW997 Motor Replacement
Ce dont vous avez besoin
  1. DeWalt DW997 Motor Replacement, Speed Switch: étape 1, image 1 de 2 DeWalt DW997 Motor Replacement, Speed Switch: étape 1, image 2 de 2
    • Remove seven 21 mm Torx T15 screws.
    • Remove one 18 mm Torx T10 screw.
    • After removing all screws, lift up the top yellow cover.
    • The yellow cover should easily lift up, if not, check for unscrewed screws.
    • Do not pry the two yellow covers apart, they can crack.
  2. DeWalt DW997 Motor Replacement: étape 2, image 1 de 1
    • Lift the components out of the casing. These include: motor, gear assembly, trigger assembly and chuck.
  3. DeWalt DW997 Motor Replacement: étape 3, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Using the tweezers, grab the metal leg on either side of the switch and lift it outwards from the case.
  4. DeWalt DW997 Motor Replacement: étape 4, image 1 de 1
    • Remove the other leg manually, it should easily come out.
  5. DeWalt DW997 Motor Replacement, Motor: étape 5, image 1 de 2 DeWalt DW997 Motor Replacement, Motor: étape 5, image 2 de 2
    • Use a Torx T10 screw bit to remove the four 11mm screws around the motor.
  6. DeWalt DW997 Motor Replacement: étape 6, image 1 de 2 DeWalt DW997 Motor Replacement: étape 6, image 2 de 2
    • Pull off the two wires that connect the motor to the trigger.
    • Be careful while pulling the wires as they can tear.
Kevin
Membre depuis le 09/12/16
140 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 18
Total : 2,253
