Aller au contenu principal
DeWalt DWD112 Power Cord Replacement
Ce dont vous avez besoin
  1. DeWalt DWD112 Power Cord Replacement, Power Cord: étape 1, image 1 de 1
    • Remove seven TR20 Torx Security screws from the side of the drill.
  2. DeWalt DWD112 Power Cord Replacement: étape 2, image 1 de 1
    • Remove the top cover to reveal the inside of the drill.
    • Set the top cover of the drill aside.
  3. DeWalt DWD112 Power Cord Replacement: étape 3, image 1 de 1
    • The power cord and the trigger act as a single part and must be replaced together.
    • Using one hand grab the trigger box and with the other grab the end of the wire connecting to the trigger box and disconnect the wire.
  4. DeWalt DWD112 Power Cord Replacement: étape 4, image 1 de 1
    • Disconnect the second connected wire from the top of the trigger box.
  5. DeWalt DWD112 Power Cord Replacement: étape 5, image 1 de 1
    • Lift the trigger box up to reveal the bottom side.
    • Disconnect the first connected wire from the bottom of the trigger box.
  6. DeWalt DWD112 Power Cord Replacement: étape 6, image 1 de 1
    • Disconnect the last wire from the trigger box using the same method from the previous step.
  7. DeWalt DWD112 Power Cord Replacement: étape 7, image 1 de 1
    • After all four wires are disconnected, the trigger and power cord are separated from the drill.
    • The power cord and trigger can be set aside if further disassembly is required.
Samantha McSweeney
Membre depuis le 03/07/16
407 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-3, Isaacson Spring 2016 Membre de l'équipe UMass Dartmouth, Team 2-3, Isaacson Spring 2016
UMASSD-ISAACSON-S16S2G3
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 13
Total : 1,255
