Aller au contenu principal
DeWalt_D26451 Brake Replacement
Ce dont vous avez besoin
  1. DeWalt_D26451 Brake Replacement, Pad: étape 1, image 1 de 3 DeWalt_D26451 Brake Replacement, Pad: étape 1, image 2 de 3 DeWalt_D26451 Brake Replacement, Pad: étape 1, image 3 de 3
    • Please wear safety glasses while completing this replacement guide.
    • Insert the 60 mm extension into the screw driver which has the t15 torx bit installed in order to make a t-handle grip.
    • Turn the screwdriver counter-clockwise to loosen all three screws in the disc pad.
  2. DeWalt_D26451 Brake Replacement: étape 2, image 1 de 2 DeWalt_D26451 Brake Replacement: étape 2, image 2 de 2
    • Turn the disc pad over and remove the loosened screws.
    • When the screws are removed, the disc pad will come off of the sander.
  3. DeWalt_D26451 Brake Replacement, Brake: étape 3, image 1 de 1
    • Please wear safety glasses while completing this repair guide.
    • Loosen and remove the three screws on the bottom of the sander that holds the disc pad to the bottom of the sander.
  4. DeWalt_D26451 Brake Replacement: étape 4, image 1 de 1
    • After the T20 torx bolts have been removed, remove the disc pad from the sander.
  5. DeWalt_D26451 Brake Replacement: étape 5, image 1 de 1
    • When the disc pad is removed, the brake is located directly under it. Remove the brake from the sander.
Shelby LeQuire
Membre depuis le 01/29/16
639 Réputation
5 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 30
Total : 2,051
