Aller au contenu principal
Definitive Technology W7 Access Panel Replacement
Ce dont vous avez besoin
  1. Definitive Technology W7 Access Panel Replacement, Access Panel: étape 1, image 1 de 1
    • Wedge the spudger in any of the four corners of the panel and apply downward pressure on the spudgers handle to pry the panel away from the speaker housing.
    • Repeat this procedure around the perimeter until the panel releases, then lift the panel up by hand.
  2. Definitive Technology W7 Access Panel Replacement: étape 2, image 1 de 2 Definitive Technology W7 Access Panel Replacement: étape 2, image 2 de 2
    • Remove the thirteen 5 mm Phillips #0 screws.
    • Once all screws have been removed, gently pull up on the black panel to remove it from the top of the speaker.
  3. Definitive Technology W7 Access Panel Replacement: étape 3, image 1 de 3 Definitive Technology W7 Access Panel Replacement: étape 3, image 2 de 3 Definitive Technology W7 Access Panel Replacement: étape 3, image 3 de 3
    • The gray mesh bag covering the speaker will now be exposed.
    • Flick the switch on the middle of the lock down to loosen the sack.
    • Pull upwards on the locking mechanism to loosen the drawstring. Stop pulling when the mesh bag is loose enough that it can be pulled downwards.
  4. Definitive Technology W7 Access Panel Replacement: étape 4, image 1 de 2 Definitive Technology W7 Access Panel Replacement: étape 4, image 2 de 2
    • Remove the four screws on top of the device on each corner with a Phillips #0 screwdriver.
    • Remove the black panel.
Brendan Thibault
Membre depuis le 10/26/22
339 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-5, Petersen Fall 2022 Membre de l'équipe UMass Dartmouth, Team 2-5, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G5
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 9
Total : 171
