Aller au contenu principal
Definitive Technology W7 Motherboard Replacement
Ce dont vous avez besoin
  1. Definitive Technology W7 Motherboard Replacement, Motherboard: étape 1, image 1 de 3 Definitive Technology W7 Motherboard Replacement, Motherboard: étape 1, image 2 de 3 Definitive Technology W7 Motherboard Replacement, Motherboard: étape 1, image 3 de 3
    • Flip the speaker upside down, then use the Phillips #2 screwdriver remove the 4 screws securing the bottom cover.
    • The screw next to the I/O panel will be approximately 20 mm in length. The other screws will be approximately 35 mm in length.
    • Use the metal spudger to remove all rubber feet.
    • Unscrew all four screws from under the rubber feet.
    • These screws will be approximately 35 mm in length.
    • You can now use the prying tool to pry the bottom panel off the speaker.
  2. Definitive Technology W7 Motherboard Replacement: étape 2, image 1 de 1
    • Using a Phillips #2 screwdriver, remove the 5 screws from the motherboard.
    • These screws are approximately 8 mm in length.
  3. Definitive Technology W7 Motherboard Replacement: étape 3, image 1 de 2 Definitive Technology W7 Motherboard Replacement: étape 3, image 2 de 2
    • Push up the locking tabs on the sides of the ribbon cable connector.
    • Gently pull the ribbon cable out from the connector to remove it.
  4. Definitive Technology W7 Motherboard Replacement: étape 4, image 1 de 2 Definitive Technology W7 Motherboard Replacement: étape 4, image 2 de 2
    • Tilt the motherboard outwards from the speaker.
    • Remove all five connectors from the motherboard.
    • Remove the motherboard from the speaker.
  5. Definitive Technology W7 Motherboard Replacement: étape 5, image 1 de 2 Definitive Technology W7 Motherboard Replacement: étape 5, image 2 de 2
    • Using the Phillips #2 screwdriver, remove the three screws from the network card.
    • These screws are approximately 8mm in length.
    • Remove the network card from the motherboard.
Magnus Maillet
Membre depuis le 10/26/22
171 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 2-5, Petersen Fall 2022 Membre de l'équipe UMass Dartmouth, Team 2-5, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G5
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 14
Total : 280
