Introduction
This guide outlines how to replace a tweeter from the Definitive Technology W7, with a model number of 093207098505. The motivation behind removing/replacing this part is that defective tweeters are a common symptom of distorted/poor audio. There are no potentially harmful things that can be encountered during this guide.
Ce dont vous avez besoin
Wedge the spudger in any of the four corners of the panel and apply downward pressure on the spudgers handle to pry the panel away from the speaker housing.
Repeat this procedure around the perimeter until the panel releases, then lift the panel up by hand.
Pull gently on the two red wires to disconnect them individually from the tweeter.
