Ce dont vous avez besoin
Unscrew the nine PH#0 captive screws on the bottom of the device.
Use a pick to run along the outside of the device popping all the clips. Prying should not be necessary.
Pull carefully, but firmly, on the battery cable until it becomes detached.
Use a plastic spudger to lift up the flap. Use the flap to pull the connector straight away from the board (towards the battery).
