Introduction
If your device does not properly hang to the bottom of compatible Dell monitors, you may need to replace one or both of its hangers.
Ce dont vous avez besoin
Use a Jimmy to peel off the screen stuck to the front of the speaker.
Start from any corner and use the Jimmy to get under the screen. Once one side lifts up, you can use your fingers to peel the rest off.
Remove the screws from the hangers you are looking to replace using a JIS #1 screwdriver.
