Aller au contenu principal
Dell Adamo XPS Palm Rest Disassembly
Ce dont vous avez besoin
    • Turn off the laptop before doing anything to the laptop.
    • Then turn the laptop around on its back.
    • On the back of the computer there is a latch that you have to slide and hold in order to remove the battery.
    • Then you have to push the computer battery towards the computer and rotate upwards.
    • Finally lift the battery out of the computer.
    • Turn the computer around and remove the eighteen screws on the base cover.
    • The screws that secure the base cover are of different sizes. Note the location and size of the screws as you remove them so that you can replace them correctly
    • You aren't actually taking apart the display but only opening it up to gain access to the palm rest panel and keyboard.
    • Use your fingers to ease the palm rest assembly from the computer.
    • Pull on the plastic tab on top of the cables to avoid damaging the connectors.
    • Exercise extreme care while lifting the palm rest assembly to avoid damaging the function key cable.
    • Lift the palm rest assembly to access the function key cable.
    • To prevent damage to the function key cable, do not disconnect the function key cable from the palm rest.
    • Disconnect the function key cable from the connector on the system board.
    • Lift the connector latch that secures the touch pad cable to the touch pad connector and remove the cable.
    • To prevent damage to the display hinges, ensure that you do not adjust the angle between the display and the computer base after removing the palm rest assembly.
    • Lift the palm rest assembly off the computer base.
Christopher Melo-Pelaez
Membre depuis le 10/27/17
1 921 Réputation
9 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 193
