Aller au contenu principal
Introduction
In this guide, we will show you how to remove and replace the Display Back-Cover.
Pièces
Aucune pièce spécifiée.
  1. Working on an electrical device while plugged in can cause injury due to electrical shock. Ensure that all external power is disconnected from the device.
    • Working on an electrical device while plugged in can cause injury due to electrical shock. Ensure that all external power is disconnected from the device.
    • Close the device and turn the device over.
  2. Remove (2) 5 mm Phillips head screws attaching the small access panel to the base using a Phillips # 1 screwdriver.
    • Remove (2) 5 mm Phillips head screws attaching the small access panel to the base using a Phillips # 1 screwdriver.
    • The (2) screws are attached to the base panel with retaining clips and won't completely detach from the panel.
  3. Remove the small access panel using a heavy duty spudger. Remove the small access panel using a heavy duty spudger. Remove the small access panel using a heavy duty spudger.
    • Remove the small access panel using a heavy duty spudger.
    • CAUTION: Solid-state drives are fragile. Exercise care when handling the hard drive.
    • CAUTION: To avoid data loss, do not remove the solid-state drive while the computer is in sleep or on state.
  4. Using the pull tab, pivot the solid-state drive bracket and peel off the bracket from the tabs on the computer base.
    • Using the pull tab, pivot the solid-state drive bracket and peel off the bracket from the tabs on the computer base.
  5. Using the pull tab, disconnect the solid-state drive cable from the system board.
    • Using the pull tab, disconnect the solid-state drive cable from the system board.
  6. Remove the screws that secure the solid-state drive assembly to the computer base.
    • Remove the screws that secure the solid-state drive assembly to the computer base.
  7. Lift the solid-state drive assembly off the computer base. Make sure the screws are off the solid-state assembly.
    • Lift the solid-state drive assembly off the computer base.
    • Make sure the screws are off the solid-state assembly.
  8. Slide and lift the solid-state drive off the solid-state assembly.
    • Slide and lift the solid-state drive off the solid-state assembly.
  9. CAUTION: Solid-state drives are fragile. Exercise care when handling the hard drive.
    • Slide the new solid-state drive into the solid-state drive assembly.
  10. Replace the screw that secures the solid-state drive assembly with the screw holes on the computer base.
    • Replace the screw that secures the solid-state drive assembly with the screw holes on the computer base.
  11. Align the screw holes on the solid-state drive assembly with the screw holes on the computer base.
    • Align the screw holes on the solid-state drive assembly with the screw holes on the computer base.
  12. Replace the screws that secure the solid-state drive assembly to the computer base.
    • Replace the screws that secure the solid-state drive assembly to the computer base.
  13. Connect the solid-state drive cable to the system board.
    • Connect the solid-state drive cable to the system board.
  14. Align the screws on the solid-state drive bracket with the screw holes on the solid-state drive assembly.
    • Align the screws on the solid-state drive bracket with the screw holes on the solid-state drive assembly.
  15. Replace the screws that secure the solid-state drive bracket to the solid-state drive assembly.
    • Replace the screws that secure the solid-state drive bracket to the solid-state drive assembly.
  16. WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Lift the latches and disconnect the keyboard and keyboard-backlight cables from the system board
  17. Remove the screws that secure the palm-rest assembly to the computer base. Remove the screws that secure the palm-rest assembly to the computer base.
    • Remove the screws that secure the palm-rest assembly to the computer base.
  18. Lift the computer base slightly and push the release tabs on the palm-rest assembly until it pops out.
    • Lift the computer base slightly and push the release tabs on the palm-rest assembly until it pops out.
  19. Turn the computer over and open the display as far as possible.
    • Turn the computer over and open the display as far as possible.
  20. Using a plastic scribe, pry up along the edges of the palm-rest assembly.
    • Using a plastic scribe, pry up along the edges of the palm-rest assembly.
  21. Gently lift the palm-rest assembly and turn it over.
    • Gently lift the palm-rest assembly and turn it over.
  22. Lift the connector latch and disconnect the power-button board cable from the system board. Lift the connector latch and disconnect the power-button board cable from the system board.
    • Lift the connector latch and disconnect the power-button board cable from the system board.
    • Remove the Keyboard.
    • Remove the power-button board.
    • Remove the status-light board.
    • Remove the touchpad.
    • Replace the touchpad.
    • Replace the status-light board.
    • Replace the power-button board.
    • Replace the keyboard.
  23. Connect the power-button board cable to the system board.
    • Connect the power-button board cable to the system board.
  24. Align the palm-rest assembly on the computer base and snap it into place.
    • Align the palm-rest assembly on the computer base and snap it into place.
    • Close the display and turn the computer over.
    • Replace the screws that secure the palm-rest assembly to the computer base.
    • Connect the keyboard cable and the keyboard-backlight cable to the system board.
  25. WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
  26. Remove the screws that secure the hinge caps to the display hinges. Remove the screws that secure the hinge caps to the display hinges.
    • Remove the screws that secure the hinge caps to the display hinges.
  27. Fix Kits pour batteries d'iPhone
    Seulement $29.99
    Buy Now
    Seulement $29.99
    Buy Now
  28. Slide and lift the hinge caps off the display hinges.
    • Slide and lift the hinge caps off the display hinges.
  29. Close the display and turn the computer over.
  30. Peel off the adhesive tape from the wireless card.
    • Peel off the adhesive tape from the wireless card.
  31. Remove the screw that secures the wireless-card bracket to the wireless card.
    • Remove the screw that secures the wireless-card bracket to the wireless card.
  32. Disconnect the antenna cables from the wireless card.
    • Disconnect the antenna cables from the wireless card.
    • Turn the computer over and open the display.
  33. Peel off the adhesive tapes that secure the antenna cables to the system board.
    • Peel off the adhesive tapes that secure the antenna cables to the system board.
    • Make note of the cable routing before removing any cable from its routing guide.
  34. Remove the antenna cables from the routing guides on the display hinges.
    • Remove the antenna cables from the routing guides on the display hinges.
  35. Lift the connector latch and disconnect the display cable from the system board. Lift the connector latch and disconnect the display cable from the system board.
    • Lift the connector latch and disconnect the display cable from the system board.
  36. Remove the display cable from the routing guides on the display hinges.
    • Remove the display cable from the routing guides on the display hinges.
  37. Disconnect the logo-board cable from the system board and remove it from the routing guides on the display hinges.
    • Disconnect the logo-board cable from the system board and remove it from the routing guides on the display hinges.
  38. Remove the screws that secure the display assembly to the computer base.
    • Remove the screws that secure the display assembly to the computer base.
  39. Lift the display assembly off the computer base.
    • Lift the display assembly off the computer base.
    • Align the screw holes on the display hinges with the screw holes on the computer base.
  40. Replace the screws that secure the display hinges to the computer base.
    • Replace the screws that secure the display hinges to the computer base.
  41. Route the logo-board cable through the routing guides on the display hinge and connect the logo-board cable to the system board.
    • Route the logo-board cable through the routing guides on the display hinge and connect the logo-board cable to the system board.
  42. Route the display cable through the routing guides on the display hinge.
    • Route the display cable through the routing guides on the display hinge.
  43. Slide the display cable into the connector on the system board and press down the latch to secure the cable.
    • Slide the display cable into the connector on the system board and press down the latch to secure the cable.
  44. Route the antenna cables through the routing guides on the display hinges.
    • Route the antenna cables through the routing guides on the display hinges.
  45. Adhere the adhesive tapes that secure the antenna cables to the system board.
    • Adhere the adhesive tapes that secure the antenna cables to the system board.
  46. Connect the antenna cables to the wireless card.
    • Connect the antenna cables to the wireless card.
  47. Replace the screw that secures the wireless-card bracket to the wireless card. Replace the screw that secures the wireless-card bracket to the wireless card.
    • Replace the screw that secures the wireless-card bracket to the wireless card.
  48. Adhere the adhesive tape to the wireless card.
    • Adhere the adhesive tape to the wireless card.
  49. Align the screw holes on the hinge caps with the screw holes on the display hinges.
    • Align the screw holes on the hinge caps with the screw holes on the display hinges.
    • Replace the screws that secure the hinge caps to the display hinges.
  50. WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer. Lift the connector latches and disconnect the touchpad cable and the status-light cable from the power-button board. Lift the connector latches and disconnect the touchpad cable and the status-light cable from the power-button board.
    • Lift the connector latches and disconnect the touchpad cable and the status-light cable from the power-button board.
  51. Peel the touchpad cable and status-light cable off the keyboard bracket.
    • Peel the touchpad cable and status-light cable off the keyboard bracket.
  52. Lift the keyboard bracket off the palm-rest assembly.
    • Lift the keyboard bracket off the palm-rest assembly.
  53. Remove the screws that secure the keyboard to the palm-rest assembly.
    • Remove the screws that secure the keyboard to the palm-rest assembly.
  54. Slide and lift the keyboard, along with the cables, off the palm-rest assembly.
    • Slide and lift the keyboard, along with the cables, off the palm-rest assembly.
  55. Align the screw holes on the NEW keyboard with the screw holes on the palm-rest assembly.
    • Align the screw holes on the NEW keyboard with the screw holes on the palm-rest assembly.
  56. Replace the screws that secure the keyboard to the palm-rest assembly.
    • Replace the screws that secure the keyboard to the palm-rest assembly.
    • Align the screw holes on the keyboard bracket with the screw holes on the palm-rest assembly.
  57. Replace the screws that secure the keyboard bracket to the palm-rest assembly.
    • Replace the screws that secure the keyboard bracket to the palm-rest assembly.
  58. Adhere the touchpad cable and status-light cable to the keyboard bracket. Adhere the touchpad cable and status-light cable to the keyboard bracket.
    • Adhere the touchpad cable and status-light cable to the keyboard bracket.
  59. Slide the touchpad cable and the status-light cable into their respective connectors on the power-button board and press down the latches to secure the cables.
    • Slide the touchpad cable and the status-light cable into their respective connectors on the power-button board and press down the latches to secure the cables.
  60. WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Using your fingertips, carefully pry up the inside edges of the display bezel.
  61. Carefully lift the display bezel and turn it over.
    • Carefully lift the display bezel and turn it over.
    • Lift the connector latches and disconnect the display-board cables from the logo board.
  62. Disconnect the logo-board cable from the logo board. Disconnect the logo-board cable from the logo board.
    • Disconnect the logo-board cable from the logo board.
    • Connect the logo-board cable to the logo board.
    • Slide the display-board cables to their respective connectors on the logo board and press down the latches to secure the cables.
    • Turn the NEW display bezel over.
  63. Align the display bezel with the display back-cover and gently snap the display bezel into place.
    • Align the display bezel with the display back-cover and gently snap the display bezel into place.
  64. Remove the screws that secure the display panel to the display back-cover. Remove the screws that secure the display panel to the display back-cover. Remove the screws that secure the display panel to the display back-cover.
    • Remove the screws that secure the display panel to the display back-cover.
  65. Gently lift the display panel and turn it over.
    • Gently lift the display panel and turn it over.
  66. Lift the connector latch and disconnect the display cable from the display panel. Lift the connector latch and disconnect the display cable from the display panel. Lift the connector latch and disconnect the display cable from the display panel.
    • Lift the connector latch and disconnect the display cable from the display panel.
  67. Connect the display cable to the NEW display panel and press down on the connector latch to secure the cable. Connect the display cable to the NEW display panel and press down on the connector latch to secure the cable. Connect the display cable to the NEW display panel and press down on the connector latch to secure the cable.
    • Connect the display cable to the NEW display panel and press down on the connector latch to secure the cable.
    • Turn the display panel over.
  68. Align the screw holes on the display panel with the screw holes on the display back-cover.
    • Align the screw holes on the display panel with the screw holes on the display back-cover.
  69. Replace the screws that secure the display panel to the display back-cover.
    • Replace the screws that secure the display panel to the display back-cover.
  70. WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer.  After working inside your computer, follow the instructions in After Working Inside Your Computer.
  71. Disconnect the camera cable from the camera module. Disconnect the camera cable from the camera module.
    • Disconnect the camera cable from the camera module.
  72. Using a plastic scribe, pry the camera module off the display back-cover. Using a plastic scribe, pry the camera module off the display back-cover.
    • Using a plastic scribe, pry the camera module off the display back-cover.
  73. Using the alignment posts place the NEW camera module on the display back-cover and snap it into place.
    • Using the alignment posts place the NEW camera module on the display back-cover and snap it into place.
  74. Connect the camera cable to the camera module. Connect the camera cable to the camera module.
    • Connect the camera cable to the camera module.
  75. WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
  76. Note the display cable routing and peel the camera cable off the display back-cover.
    • Note the display cable routing and peel the camera cable off the display back-cover.
    • Place the NEW display back-cover on a flat surface.
    • Adhere the display-board cable and the camera cable to the display back-cover.
Terrence15
Membre depuis le 18/12/2017
70 858 Réputation
442 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
930 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 41
