Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
In this guide, we will be showing you how to remove and replace the Hard Drive.
Pièces
Aucune pièce spécifiée.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • To avoid data loss, do not remove the hard drive while the computer is in sleep or on state.
    • Remove the screws that secure the hard-drive assembly to the computer base.
  2. Using the pull tab, disconnect the hard-drive cable from the system board.
    • Using the pull tab, disconnect the hard-drive cable from the system board.
  3. Lift the hard-drive assembly off the computer base.
    • Lift the hard-drive assembly off the computer base.
  4. Remove the screws that secure the hard-drive bracket to the hard drive.
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  5. Lift the hard drive off the hard-drive bracket.
    • Lift the hard drive off the hard-drive bracket.
  6. Disconnect the interposer from the hard drive.
    • Disconnect the interposer from the hard drive.
  7. Connect the new interposer to the new hard drive.
    • Connect the new interposer to the new hard drive.
  8. Align the screw holes on the hard-drive bracket with the screw holes on the hard-drive assembly.
    • Align the screw holes on the hard-drive bracket with the screw holes on the hard-drive assembly.
  9. Replace the screws that secure the hard-drive bracket to the hard-drive assembly.
    • Replace the screws that secure the hard-drive bracket to the hard-drive assembly.
  10. Align the screw holes on the hard-drive assembly to the computer base.
    • Align the screw holes on the hard-drive assembly to the computer base.
  11. Replace the screws that secure the hard-drive assembly to the computer base.
    • Replace the screws that secure the hard-drive assembly to the computer base.
  12. Connect the hard-drive cable to the system board.
    • Connect the hard-drive cable to the system board.
Terrence15
Membre depuis le 18/12/2017
72 973 Réputation
442 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
33 membres
1 954 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 93
