Aller au contenu principal
Dell Alienware 13 R2 Display Back-Cover Replacement
Ce dont vous avez besoin
  1. Dell Alienware 13 R2 Display Back-Cover Replacement, Turning Over the PC: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer After working inside your computer, follow the instructions in After Working Inside Your Computer For more safety best practices, see the regulatory compliance home page.
    • Close the display and turn the computer over.
  2. Dell Alienware 13 R2 Display Back-Cover Replacement, Loosen the screws: étape 2, image 1 de 1
    • Loosen the captive screws that secure the base panel to the computer base.
  3. Dell Alienware 13 R2 Display Back-Cover Replacement, Releasing the Tabs: étape 3, image 1 de 1
    • Using a plastic scribe, gently release the tabs that secure the base panel to the computer base.
  4. Dell Alienware 13 R2 Display Back-Cover Replacement, Disconnecting the Battery Cable: étape 4, image 1 de 2 Dell Alienware 13 R2 Display Back-Cover Replacement, Disconnecting the Battery Cable: étape 4, image 2 de 2
    • Disconnect the battery cable from the battery-cable connector.
    • Turn the computer over.
  5. Dell Alienware 13 R2 Display Back-Cover Replacement, Power Button: étape 5, image 1 de 1
    • Press and hold the power button for 5 seconds to ground the system board.
    • Connect the battery cable to the battery-cable connector.
  6. Dell Alienware 13 R2 Display Back-Cover Replacement, Aligning the tabs: étape 7, image 1 de 1
    • Align the tabs on the base panel with the slots on the computer base and snap the base panel into place.
  7. Dell Alienware 13 R2 Display Back-Cover Replacement, Tighten the screws: étape 8, image 1 de 1
    • Tighten the captive screws that secure the base panel to the computer base.
  8. Dell Alienware 13 R2 Display Back-Cover Replacement, Removing the Screws: étape 9, image 1 de 2 Dell Alienware 13 R2 Display Back-Cover Replacement, Removing the Screws: étape 9, image 2 de 2
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Remove the screws that secure the solid-state drive bracket to the solid-state drive assembly.
  9. Dell Alienware 13 R2 Display Back-Cover Replacement, Peel off Computer Base Tabs: étape 10, image 1 de 2 Dell Alienware 13 R2 Display Back-Cover Replacement, Peel off Computer Base Tabs: étape 10, image 2 de 2
    • Using the pull tab, pivot the solid-state drive bracket and peel off the bracket from the tabs on the computer base.
  10. Dell Alienware 13 R2 Display Back-Cover Replacement, Disconnecting the Solid-State Drive Cable: étape 11, image 1 de 1
    • Using the pull tab, disconnect the solid-state drive cable from the system board.
  11. Dell Alienware 13 R2 Display Back-Cover Replacement, Removing the Solid-State Drive: étape 12, image 1 de 2 Dell Alienware 13 R2 Display Back-Cover Replacement, Removing the Solid-State Drive: étape 12, image 2 de 2
    • Remove the screws that secure the solid-state drive assembly to the computer base.
  12. Dell Alienware 13 R2 Display Back-Cover Replacement, Lifting the Solid-State Assembly: étape 13, image 1 de 1
    • Lift the solid-state drive assembly off the computer base.
  13. Dell Alienware 13 R2 Display Back-Cover Replacement, Remove the Screw: étape 14, image 1 de 1
    • Remove the screw that secures the solid-state drive to the solid-state drive assembly.
  14. Dell Alienware 13 R2 Display Back-Cover Replacement, Lift the Solid-State Assembly.: étape 15, image 1 de 2 Dell Alienware 13 R2 Display Back-Cover Replacement, Lift the Solid-State Assembly.: étape 15, image 2 de 2
    • Slide and lift the solid-state drive off the solid-state drive assembly.
  15. Dell Alienware 13 R2 Display Back-Cover Replacement, The New Solid-State Drive: étape 16, image 1 de 1
    • Slide the NEW solid-state drive into the slot on the solid-state drive assembly.
  16. Dell Alienware 13 R2 Display Back-Cover Replacement, Screw Replacement: étape 17, image 1 de 2 Dell Alienware 13 R2 Display Back-Cover Replacement, Screw Replacement: étape 17, image 2 de 2
    • Replace the screw that secures the solid-state drive to the solid-state drive assembly.
  17. Dell Alienware 13 R2 Display Back-Cover Replacement, Align the Screws: étape 18, image 1 de 2 Dell Alienware 13 R2 Display Back-Cover Replacement, Align the Screws: étape 18, image 2 de 2
    • Align the screw holes on the solid-state drive assembly with the screw holes on the computer base.
  18. Dell Alienware 13 R2 Display Back-Cover Replacement, Replace the Screws: étape 19, image 1 de 1
    • Replace the screws that secure the solid-state drive assembly to the computer base.
  19. Dell Alienware 13 R2 Display Back-Cover Replacement, Connect the Cable to the System Board: étape 20, image 1 de 1
    • Connect the solid-state drive cable to the system board.
  20. Dell Alienware 13 R2 Display Back-Cover Replacement, Align the Screw Holes: étape 21, image 1 de 1
    • Align the screw holes on the solid-state drive bracket with the screw holes on the solid-state drive assembly.
  21. Dell Alienware 13 R2 Display Back-Cover Replacement, Replace the Screws: étape 22, image 1 de 2 Dell Alienware 13 R2 Display Back-Cover Replacement, Replace the Screws: étape 22, image 2 de 2
    • Replace the screws that secure the solid-state drive bracket to the solid-state drive assembly.
  22. Dell Alienware 13 R2 Display Back-Cover Replacement, Lifting the Latches: étape 23, image 1 de 1
    • Lift the latches and disconnect the keyboard and keyboard-backlight cables from the system board.
  23. Dell Alienware 13 R2 Display Back-Cover Replacement, Remove the Screws: étape 24, image 1 de 1
    • Remove the screws that secure the palm-rest assembly to the computer base.
  24. Dell Alienware 13 R2 Display Back-Cover Replacement, Lift the Computer Base: étape 25, image 1 de 1
    • Lift the computer base slightly and push the release tabs on the palm-rest assembly until it pops out.
    • Turn the computer over and open the display as far as possible.
  25. Dell Alienware 13 R2 Display Back-Cover Replacement, Prying the Palm-Rest Assembly: étape 27, image 1 de 1
    • Using a plastic scribe, pry up along the edges of the palm-rest assembly.
  26. Dell Alienware 13 R2 Display Back-Cover Replacement, Lift the Palm-Rest Assembly: étape 28, image 1 de 1
    • Gently lift the palm-rest assembly and turn it over.
  27. Dell Alienware 13 R2 Display Back-Cover Replacement, Lift the Connector Latch: étape 29, image 1 de 2 Dell Alienware 13 R2 Display Back-Cover Replacement, Lift the Connector Latch: étape 29, image 2 de 2
    • Lift the connector latch and disconnect the power-button board cable from the system board.
  28. Dell Alienware 13 R2 Display Back-Cover Replacement, Lift the Palm-Rest Assembly: étape 30, image 1 de 1
    • Lift the palm-rest assembly off the computer base.
  29. Dell Alienware 13 R2 Display Back-Cover Replacement, Removing: étape 31, image 1 de 1
    • Remove the keyboard.
    • Remove the power-button board.
    • Remove the status-light board.
    • Remove the Touchpad.
    • Replace the touchpad.
    • Replace the status-light board.
    • Replace the power-button board.
    • Replace the keyboard.
    • Connect the power-button board cable to the system board.
  30. Dell Alienware 13 R2 Display Back-Cover Replacement, Align the Palm-Rest Assembly: étape 34, image 1 de 1
    • Align the palm-rest assembly on the computer base and snap it into place.
    • Replace the screws that secure the palm-rest assembly to the computer base.
    • Connect the keyboard cable and the keyboard-backlight cable to the system board.
  31. Dell Alienware 13 R2 Display Back-Cover Replacement, Remove the Screws: étape 39, image 1 de 2 Dell Alienware 13 R2 Display Back-Cover Replacement, Remove the Screws: étape 39, image 2 de 2
    • Remove the screws that secure the hinge caps to the display hinges.
  32. Dell Alienware 13 R2 Display Back-Cover Replacement, Lifting the Hinge Caps: étape 40, image 1 de 1
    • Slide and lift the hinge caps off the display hinges.
  33. Dell Alienware 13 R2 Display Back-Cover Replacement, Remove the Screw: étape 42, image 1 de 2 Dell Alienware 13 R2 Display Back-Cover Replacement, Remove the Screw: étape 42, image 2 de 2
    • Remove the screw that secures the wireless-card bracket to the wireless card.
  34. Dell Alienware 13 R2 Display Back-Cover Replacement, Disconnect the Antenna Cables: étape 43, image 1 de 1
    • Disconnect the antenna cables from the wireless card.
    • Turn the computer over and open the display.
  35. Dell Alienware 13 R2 Display Back-Cover Replacement, Remove the Antenna Cables: étape 45, image 1 de 1
    • Remove the antenna cables from the routing guides on the display hinges.
  36. Dell Alienware 13 R2 Display Back-Cover Replacement, Disconnect the Display Cable: étape 46, image 1 de 2 Dell Alienware 13 R2 Display Back-Cover Replacement, Disconnect the Display Cable: étape 46, image 2 de 2
    • Lift the connector latch and disconnect the display cable from the system board.
  37. Dell Alienware 13 R2 Display Back-Cover Replacement, Remove the Display Cable: étape 47, image 1 de 2 Dell Alienware 13 R2 Display Back-Cover Replacement, Remove the Display Cable: étape 47, image 2 de 2
    • Remove the display cable from the routing guides on the display hinges.
  38. Dell Alienware 13 R2 Display Back-Cover Replacement, Disconnect the Logo-Board Cable: étape 48, image 1 de 1
    • Disconnect the logo-board cable from the system board and remove it from the routing guides on the display hinges.
  39. Dell Alienware 13 R2 Display Back-Cover Replacement, Remove the Screws: étape 49, image 1 de 1
    • Remove the screws that secure the display assembly to the computer base.
    • Lift the display assembly off the computer base.
  40. Dell Alienware 13 R2 Display Back-Cover Replacement, Align the Screw Holes: étape 51, image 1 de 1
    • Align the screw holes on the display hinges with the screw holes on the computer base.
  41. Dell Alienware 13 R2 Display Back-Cover Replacement, Replace the Screws: étape 52, image 1 de 1
    • Replace the screws that secure the display hinges to the computer base.
  42. Dell Alienware 13 R2 Display Back-Cover Replacement, Routing the Logo-Board Cable: étape 53, image 1 de 1
    • Route the logo-board cable through the routing guides on the display hinge and connect the logo-board cable to the system board.
  43. Dell Alienware 13 R2 Display Back-Cover Replacement, Route the Cable: étape 54, image 1 de 1
    • Route the display cable through the routing guides on the display hinge.
  44. Dell Alienware 13 R2 Display Back-Cover Replacement, Slide the Display Cable: étape 55, image 1 de 1
    • Slide the display cable into the connector on the system board and press down the latch to secure the cable.
    • Route the antenna cables through the routing guides on the display hinges.
  45. Dell Alienware 13 R2 Display Back-Cover Replacement, Adhere the Adhesive Tapes: étape 57, image 1 de 1
    • Adhere the adhesive tapes that secure the antenna cables to the system board.
    • Connect the antenna cables to the wireless card.
    • Replace the screw that secures the wireless-card bracket to the wireless card.
  46. Dell Alienware 13 R2 Display Back-Cover Replacement, Align the Screw Holes: étape 62, image 1 de 1
    • Align the screw holes on the hinge caps with the screw holes on the display hinges.
    • Replace the screws that secure the hinge caps to the display hinges.
  47. Dell Alienware 13 R2 Display Back-Cover Replacement, Prying the Edges: étape 64, image 1 de 1
    • Using your fingertips, carefully pry up the inside edges of the display bezel.
    • Carefully lift the display bezel and turn it over.
  48. Dell Alienware 13 R2 Display Back-Cover Replacement, Lifting the Latches: étape 66, image 1 de 1
    • Lift the connector latches and disconnect the display-board cables from the logo board.
  49. Dell Alienware 13 R2 Display Back-Cover Replacement, Disconnect the Logo-Board Cable: étape 67, image 1 de 2 Dell Alienware 13 R2 Display Back-Cover Replacement, Disconnect the Logo-Board Cable: étape 67, image 2 de 2
    • Disconnect the logo-board cable from the logo board.
  50. Dell Alienware 13 R2 Display Back-Cover Replacement, Connect the Logo Board Cable: étape 68, image 1 de 1
    • Connect the logo-board cable to the logo board.
  51. Dell Alienware 13 R2 Display Back-Cover Replacement, Slide the Display-Board Cables: étape 69, image 1 de 1
    • Slide the display-board cables to their respective connectors on the logo board and press down the latches to secure the cables.
    • Turn the display bezel over.
  52. Dell Alienware 13 R2 Display Back-Cover Replacement, Align the Bezel: étape 71, image 1 de 1
    • Align the display bezel with the display back-cover and gently snap the display bezel into place.
  53. Dell Alienware 13 R2 Display Back-Cover Replacement, Remove the Screws: étape 72, image 1 de 1
  54. Dell Alienware 13 R2 Display Back-Cover Replacement, Lift the Display Panel: étape 73, image 1 de 1
    • Gently lift the display panel and turn it over.
  55. Dell Alienware 13 R2 Display Back-Cover Replacement, Disconnecting the Display Cable: étape 74, image 1 de 2 Dell Alienware 13 R2 Display Back-Cover Replacement, Disconnecting the Display Cable: étape 74, image 2 de 2
    • Lift the connector latch and disconnect the display cable from the display panel.
  56. Dell Alienware 13 R2 Display Back-Cover Replacement, Connect the Display Cable: étape 75, image 1 de 1
    • Connect the NEW display cable to the display panel and press down on the connector latch to secure the cable.
    • Turn the display panel over.
  57. Dell Alienware 13 R2 Display Back-Cover Replacement, Lifting the Latch: étape 78, image 1 de 3 Dell Alienware 13 R2 Display Back-Cover Replacement, Lifting the Latch: étape 78, image 2 de 3 Dell Alienware 13 R2 Display Back-Cover Replacement, Lifting the Latch: étape 78, image 3 de 3
  58. Dell Alienware 13 R2 Display Back-Cover Replacement, Securing the Cable: étape 79, image 1 de 1
  59. Dell Alienware 13 R2 Display Back-Cover Replacement, Align the Screw Holes: étape 81, image 1 de 1
    • Align the screw holes on the display panel with the screw holes on the display back-cover.
  60. Dell Alienware 13 R2 Display Back-Cover Replacement, Replace the Screws: étape 82, image 1 de 1
    • Replace the screws that secure the display panel to the display back-cover.
  61. Dell Alienware 13 R2 Display Back-Cover Replacement, Remove the Screws: étape 83, image 1 de 1
  62. Dell Alienware 13 R2 Display Back-Cover Replacement, Lift the Display Hinges: étape 84, image 1 de 1
    • Lift the display hinges off the display back-cover.
  63. Dell Alienware 13 R2 Display Back-Cover Replacement, Align the Screw Holes: étape 85, image 1 de 1
    • Align the screw holes on the NEW display hinges with the screw holes on the display back-cover.
  64. Dell Alienware 13 R2 Display Back-Cover Replacement, Replace the Screws: étape 86, image 1 de 1
    • Replace the screws that secure the display hinges to the display back-cover.
  65. Dell Alienware 13 R2 Display Back-Cover Replacement, Place on a Flat Surface: étape 87, image 1 de 1
  66. Dell Alienware 13 R2 Display Back-Cover Replacement, Disconnect the Camera Cable: étape 88, image 1 de 1
    • Disconnect the camera cable from the camera module.
  67. Dell Alienware 13 R2 Display Back-Cover Replacement, Prying the Camera Module: étape 89, image 1 de 1
    • Using a plastic scribe, pry the camera module off the display back-cover.
  68. Dell Alienware 13 R2 Display Back-Cover Replacement, Place the NEW Camera Module: étape 90, image 1 de 1
    • Using the alignment posts place the NEW camera module on the display back-cover and snap it into place.
  69. Dell Alienware 13 R2 Display Back-Cover Replacement, Connect the Camera Cable: étape 91, image 1 de 1
    • Connect the camera cable to the camera module.
  70. Dell Alienware 13 R2 Display Back-Cover Replacement, Peel the Display-Board Cable: étape 92, image 1 de 1
  71. Dell Alienware 13 R2 Display Back-Cover Replacement, Peel the Camera Cable: étape 93, image 1 de 2 Dell Alienware 13 R2 Display Back-Cover Replacement, Peel the Camera Cable: étape 93, image 2 de 2
    • Note the display cable routing and peel the camera cable off the display back-cover.
  72. Dell Alienware 13 R2 Display Back-Cover Replacement, Place the Display Back-Cover: étape 94, image 1 de 1
    • Place the display back-cover on a flat surface.
  73. Dell Alienware 13 R2 Display Back-Cover Replacement, Adhere the Display-Board Cable: étape 95, image 1 de 1
    • Adhere the display-board cable and the camera cable to the NEW display back-cover.
Terrence15
Membre depuis le 12/18/17
79 031 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 156
