Aller au contenu principal
Dell Alienware 13 R2 Heat-Sink Assembly Replacement
Ce dont vous avez besoin
  1. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Turning Over the PC: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer After working inside your computer, follow the instructions in After Working Inside Your Computer For more safety best practices, see the regulatory compliance home page.
    • Close the display and turn the computer over.
  2. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Loosen the screws: étape 2, image 1 de 1
    • Loosen the captive screws that secure the base panel to the computer base.
  3. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Releasing the Tabs: étape 3, image 1 de 1
    • Using a plastic scribe, gently release the tabs that secure the base panel to the computer base.
  4. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Disconnecting the Battery Cable: étape 4, image 1 de 2 Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Disconnecting the Battery Cable: étape 4, image 2 de 2
    • Disconnect the battery cable from the battery-cable connector.
    • Turn the computer over.
  5. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Power Button: étape 5, image 1 de 1
    • Press and hold the power button for 5 seconds to ground the system board.
    • Connect the battery cable to the battery-cable connector.
  6. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Aligning the tabs: étape 7, image 1 de 1
    • Align the tabs on the base panel with the slots on the computer base and snap the base panel into place.
  7. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Tighten the screws: étape 8, image 1 de 1
    • Tighten the captive screws that secure the base panel to the computer base.
  8. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Removing the Screws: étape 9, image 1 de 2 Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Removing the Screws: étape 9, image 2 de 2
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Remove the screws that secure the solid-state drive bracket to the solid-state drive assembly.
  9. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Peel off Computer Base Tabs: étape 10, image 1 de 2 Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Peel off Computer Base Tabs: étape 10, image 2 de 2
    • Using the pull tab, pivot the solid-state drive bracket and peel off the bracket from the tabs on the computer base.
  10. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Disconnecting the Solid-State Drive Cable: étape 11, image 1 de 1
    • Using the pull tab, disconnect the solid-state drive cable from the system board.
  11. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Removing the Solid-State Drive: étape 12, image 1 de 2 Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Removing the Solid-State Drive: étape 12, image 2 de 2
    • Remove the screws that secure the solid-state drive assembly to the computer base.
  12. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Lifting the Solid-State Assembly: étape 13, image 1 de 1
    • Lift the solid-state drive assembly off the computer base.
  13. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Remove the Screw: étape 14, image 1 de 1
    • Remove the screw that secures the solid-state drive to the solid-state drive assembly.
  14. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Lift the Solid-State Assembly.: étape 15, image 1 de 2 Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Lift the Solid-State Assembly.: étape 15, image 2 de 2
    • Slide and lift the solid-state drive off the solid-state drive assembly.
  15. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, The New Solid-State Drive: étape 16, image 1 de 1
    • Slide the NEW solid-state drive into the slot on the solid-state drive assembly.
  16. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Screw Replacement: étape 17, image 1 de 2 Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Screw Replacement: étape 17, image 2 de 2
    • Replace the screw that secures the solid-state drive to the solid-state drive assembly.
  17. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Align the Screws: étape 18, image 1 de 2 Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Align the Screws: étape 18, image 2 de 2
    • Align the screw holes on the solid-state drive assembly with the screw holes on the computer base.
  18. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Replace the Screws: étape 19, image 1 de 1
    • Replace the screws that secure the solid-state drive assembly to the computer base.
  19. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Connect the Cable to the System Board: étape 20, image 1 de 1
    • Connect the solid-state drive cable to the system board.
  20. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Align the Screw Holes: étape 21, image 1 de 1
    • Align the screw holes on the solid-state drive bracket with the screw holes on the solid-state drive assembly.
  21. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Replace the Screws: étape 22, image 1 de 2 Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Replace the Screws: étape 22, image 2 de 2
    • Replace the screws that secure the solid-state drive bracket to the solid-state drive assembly.
  22. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Lifting the Latches: étape 23, image 1 de 1
    • Lift the latches and disconnect the keyboard and keyboard-backlight cables from the system board.
  23. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Remove the Screws: étape 24, image 1 de 1
    • Remove the screws that secure the palm-rest assembly to the computer base.
  24. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Lift the Computer Base: étape 25, image 1 de 1
    • Lift the computer base slightly and push the release tabs on the palm-rest assembly until it pops out.
    • Turn the computer over and open the display as far as possible.
  25. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Prying the Palm-Rest Assembly: étape 27, image 1 de 1
    • Using a plastic scribe, pry up along the edges of the palm-rest assembly.
  26. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Lift the Palm-Rest Assembly: étape 28, image 1 de 1
    • Gently lift the palm-rest assembly and turn it over.
  27. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Lift the Connector Latch: étape 29, image 1 de 2 Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Lift the Connector Latch: étape 29, image 2 de 2
    • Lift the connector latch and disconnect the power-button board cable from the system board.
  28. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Lift the Palm-Rest Assembly: étape 30, image 1 de 1
    • Lift the palm-rest assembly off the computer base.
  29. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Removing: étape 31, image 1 de 1
    • Remove the keyboard.
    • Remove the power-button board.
    • Remove the status-light board.
    • Remove the Touchpad.
    • Replace the touchpad.
    • Replace the status-light board.
    • Replace the power-button board.
    • Replace the keyboard.
    • Connect the power-button board cable to the system board.
  30. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Align the Palm-Rest Assembly: étape 34, image 1 de 1
    • Align the palm-rest assembly on the computer base and snap it into place.
    • Replace the screws that secure the palm-rest assembly to the computer base.
    • Connect the keyboard cable and the keyboard-backlight cable to the system board.
  31. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Remove the Screws: étape 39, image 1 de 2 Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Remove the Screws: étape 39, image 2 de 2
    • Remove the screws that secure the hinge caps to the display hinges.
  32. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Lifting the Hinge Caps: étape 40, image 1 de 1
    • Slide and lift the hinge caps off the display hinges.
  33. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Remove the Screw: étape 42, image 1 de 2 Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Remove the Screw: étape 42, image 2 de 2
    • Remove the screw that secures the wireless-card bracket to the wireless card.
  34. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Disconnect the Antenna Cables: étape 43, image 1 de 1
    • Disconnect the antenna cables from the wireless card.
    • Turn the computer over and open the display.
  35. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Remove the Antenna Cables: étape 45, image 1 de 1
    • Remove the antenna cables from the routing guides on the display hinges.
  36. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Disconnect the Display Cable: étape 46, image 1 de 2 Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Disconnect the Display Cable: étape 46, image 2 de 2
    • Lift the connector latch and disconnect the display cable from the system board.
  37. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Remove the Display Cable: étape 47, image 1 de 2 Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Remove the Display Cable: étape 47, image 2 de 2
    • Remove the display cable from the routing guides on the display hinges.
  38. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Disconnect the Logo-Board Cable: étape 48, image 1 de 1
    • Disconnect the logo-board cable from the system board and remove it from the routing guides on the display hinges.
  39. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Remove the Screws: étape 49, image 1 de 1
    • Remove the screws that secure the display assembly to the computer base.
    • Lift the display assembly off the computer base.
  40. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Align the Screw Holes: étape 51, image 1 de 1
    • Align the screw holes on the display hinges with the screw holes on the computer base.
  41. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Replace the Screws: étape 52, image 1 de 1
    • Replace the screws that secure the display hinges to the computer base.
  42. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Routing the Logo-Board Cable: étape 53, image 1 de 1
    • Route the logo-board cable through the routing guides on the display hinge and connect the logo-board cable to the system board.
  43. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Route the Cable: étape 54, image 1 de 1
    • Route the display cable through the routing guides on the display hinge.
  44. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Slide the Display Cable: étape 55, image 1 de 1
    • Slide the display cable into the connector on the system board and press down the latch to secure the cable.
    • Route the antenna cables through the routing guides on the display hinges.
  45. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Adhere the Adhesive Tapes: étape 57, image 1 de 1
    • Adhere the adhesive tapes that secure the antenna cables to the system board.
    • Connect the antenna cables to the wireless card.
    • Replace the screw that secures the wireless-card bracket to the wireless card.
  46. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Align the Screw Holes: étape 62, image 1 de 1
    • Align the screw holes on the hinge caps with the screw holes on the display hinges.
    • Replace the screws that secure the hinge caps to the display hinges.
  47. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Remove the Screw: étape 64, image 1 de 1
    • Remove the screw that secures the power-adapter port bracket to the power-adapter port.
  48. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Lifting the Power-Adapter: étape 65, image 1 de 1
    • Lift the power-adapter port bracket off the power-adapter port.
    • Release the power-adapter port from the computer base.
  49. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Disconnecting the Speaker Cable: étape 67, image 1 de 1
    • Disconnect the speaker cable from the system board.
  50. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Remove the Screws: étape 68, image 1 de 1
    • Remove the screws that secure the system board to the computer base.
  51. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Lifting the System Board Assembly: étape 69, image 1 de 1
    • Slide and lift the system-board assembly.
    • Turn the system-board assembly over.
  52. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Disconnecting the Power-Adapter Port: étape 71, image 1 de 1
    • Disconnect the power-adapter port cable and remove the power-adapter port from the system board.
    • Connect the power-adapter port cable to the system board.
    • Turn the system board over.
  53. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Replace the Screws: étape 74, image 1 de 1
    • Replace the screws that secure the system board to the computer base.
  54. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Connecting the Speaker Cable: étape 75, image 1 de 1
    • Connect the speaker cable to the connector on the system board.
    • Align the power-adapter port to the computer base.
  55. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Align the Screw Hole: étape 77, image 1 de 1
    • Align the screw hole on the power-adapter port bracket with the screw hole on the power-adapter port.
    • Replace the screw that secures the power-adapter port bracket to the power-adapter port.
  56. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Disconnect the Fan Cables: étape 79, image 1 de 1
  57. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Remove the Screws: étape 81, image 1 de 1
    • Remove the screws that secure the heat-sink assembly to the system board.
  58. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Lifting the Heat-Sink Assembly: étape 82, image 1 de 1
    • Lift the heat-sink assembly off the system board.
  59. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Align the Screw Holes: étape 83, image 1 de 1
    • Align the screw holes on the NEW heat-sink assembly with the screw holes on the system board.
    • Replace the screws that secure the heat-sink assembly to the system board.
  60. Dell Alienware 13 R2 Heat-Sink Assembly Replacement, Connect the fan Cables: étape 86, image 1 de 1
    • Connect the fan cables to the connectors on the system board.
Terrence15
Membre depuis le 12/18/17
79 243 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 989 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 359
