Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
In this guide, we will be showing you how to remove and replace the Solid-State Drive.
Pièces
Aucune pièce spécifiée.
    • CAUTION: Solid-state drives are fragile. Exercise care when handling the hard drive.
    • CAUTION: To avoid data loss, do not remove the solid-state drive while the computer is in sleep or on state.
  1. Using the pull tab, pivot the solid-state drive bracket and peel off the bracket from the tabs on the computer base.
    • Using the pull tab, pivot the solid-state drive bracket and peel off the bracket from the tabs on the computer base.
  2. Using the pull tab, disconnect the solid-state drive cable from the system board.
    • Using the pull tab, disconnect the solid-state drive cable from the system board.
  3. Remove the screws that secure the solid-state drive assembly to the computer base.
    • Remove the screws that secure the solid-state drive assembly to the computer base.
  4. Lift the solid-state drive assembly off the computer base. Make sure the screws are off the solid-state assembly.
    • Lift the solid-state drive assembly off the computer base.
    • Make sure the screws are off the solid-state assembly.
  5. Slide and lift the solid-state drive off the solid-state assembly.
    • Slide and lift the solid-state drive off the solid-state assembly.
  6. CAUTION: Solid-state drives are fragile. Exercise care when handling the hard drive.
    • Slide the new solid-state drive into the solid-state drive assembly.
  7. Replace the screw that secures the solid-state drive assembly with the screw holes on the computer base.
    • Replace the screw that secures the solid-state drive assembly with the screw holes on the computer base.
  8. Align the screw holes on the solid-state drive assembly with the screw holes on the computer base.
    • Align the screw holes on the solid-state drive assembly with the screw holes on the computer base.
  9. Replace the screws that secure the solid-state drive assembly to the computer base.
    • Replace the screws that secure the solid-state drive assembly to the computer base.
  10. Connect the solid-state drive cable to the system board.
    • Connect the solid-state drive cable to the system board.
  11. Align the screws on the solid-state drive bracket with the screw holes on the solid-state drive assembly.
    • Align the screws on the solid-state drive bracket with the screw holes on the solid-state drive assembly.
  12. Replace the screws that secure the solid-state drive bracket to the solid-state drive assembly.
    • Replace the screws that secure the solid-state drive bracket to the solid-state drive assembly.
Ligne d'arrivée
Terrence15
Membre depuis le 18/12/2017
72 904 Réputation
442 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
32 membres
1 933 tutoriels rédigés
Hi there. Could I have a link to the full service manual you got this from? Thanks.
Aiden - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 2
Total : 140
