Introduction
This guide will show the user how to replace broken or blown speakers on a Dell Alienware 13 laptop.
Ce dont vous avez besoin
Outil utilisé dans cette étape :Heavy-Duty Spudger$4.99
Remove the small access panel using a heavy duty spudger.
Disconnect the antenna cables from the wireless card using a heavy duty spudger. The wires can be removed by applying a force directed upward, away from the device.
After removing the battery, lift up on the speakers and wires to fully removed from the base panel.
