Introduction
In this guide, we will be showing you how to remove and replace the memory modules.
Outils
Aucun outil requis.
Pièces
Aucune pièce nécessaire.
  1. WARNING:  Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin. . After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin. . After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • Close the display, and turn the computer over.
  2. Remove the screws that secure the base cover to the computer base. Remove the screws that secure the base cover to the computer base.
    • Remove the screws that secure the base cover to the computer base.
  3. Slide and lift the base cover off the computer base.
    • Slide and lift the base cover off the computer base.
  4. Align the tabs on the NEW base cover with the slots on the computer base and slide the base cover into place.
    • Align the tabs on the NEW base cover with the slots on the computer base and slide the base cover into place.
  5. Replace the screws that secure the base cover to the computer base.
    • Replace the screws that secure the base cover to the computer base.
  6. Turn the computer over and open the display.
    • Turn the computer over and open the display.
  7. WARNING:  Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer.   After working inside your computer, follow the instructions in After Working Inside Your Computer.
  8. %Livraison gratuite pour toute commande supérieure à 100 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
  9. Remove the screws that secure the battery to the computer base.
    • Remove the screws that secure the battery to the computer base.
  10. Using the battery cable, lift the battery and release it from the tabs on the computer base.
    • Using the battery cable, lift the battery and release it from the tabs on the computer base.
  11. Turn the computer over and open the display as far as possible.
    • Turn the computer over and open the display as far as possible.
  12. Press and hold the power button for five seconds to ground the system board.
    • Press and hold the power button for five seconds to ground the system board.
    • Close the display and turn the computer over.
  13. Align the tabs on the NEW battery with  the slots on the computer base.
    • Align the tabs on the NEW battery with the slots on the computer base.
  14. Align the screw holes on the battery with  the screw holes on the computer base.
    • Align the screw holes on the battery with the screw holes on the computer base.
  15. Replace the screws that secure the battery to the computer base.
    • Replace the screws that secure the battery to the computer base.
  16. Connect the battery cable to the system-board connector.
    • Connect the battery cable to the system-board connector.
  17. WARNING: Before working inside your computer, read the safety  information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer,  follow the instructions in After Working Inside Your Computer. CAUTION: To prevent damage to the memory-module connector, do  not use tools to spread the memory-module securing clips. Using your fingertips, carefully spread apart the securing clips on each end of the  memory-module connector until the memory module pops up.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory-module securing clips.
    • Using your fingertips, carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
  18. Remove the memory module from the memory-module connector. Remove the memory module from the memory-module connector.
    • Remove the memory module from the memory-module connector.
  19. Align the notch on the NEW memory module  with the tab on the memory-module  connector. Align the notch on the NEW memory module  with the tab on the memory-module  connector.
    • Align the notch on the NEW memory module with the tab on the memory-module connector.
  20. Slide the memory module firmly into the  slot at a 45-degree angle, and press the  memory module down until it clicks into place. If you do not hear the click, remove  the memory module and reinstall it.
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
Terrence15
Membre depuis le 18/12/2017
70 653 Réputation
442 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
925 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 28
