Aller au contenu principal
Dell Alienware 14 Wireless Mini-Card Replacement
Ce dont vous avez besoin
  1. Dell Alienware 14 Wireless Mini-Card Replacement, Close the Display: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin. . After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • Close the display, and turn the computer over.
  2. Dell Alienware 14 Wireless Mini-Card Replacement, Remove the Screws: étape 2, image 1 de 2 Dell Alienware 14 Wireless Mini-Card Replacement, Remove the Screws: étape 2, image 2 de 2
    • Remove the screws that secure the base cover to the computer base.
  3. Dell Alienware 14 Wireless Mini-Card Replacement, Slide and Lift the Base Cover: étape 3, image 1 de 1
    • Slide and lift the base cover off the computer base.
  4. Dell Alienware 14 Wireless Mini-Card Replacement, Align the Tabs: étape 4, image 1 de 1
    • Align the tabs on the NEW base cover with the slots on the computer base and slide the base cover into place.
  5. Dell Alienware 14 Wireless Mini-Card Replacement, Replace the Screws: étape 5, image 1 de 1
    • Replace the screws that secure the base cover to the computer base.
  6. Dell Alienware 14 Wireless Mini-Card Replacement, Turn the Computer Over: étape 6, image 1 de 1
    • Turn the computer over and open the display.
  7. Dell Alienware 14 Wireless Mini-Card Replacement, Disconnecting the Battery Cable: étape 7, image 1 de 1
  8. Dell Alienware 14 Wireless Mini-Card Replacement, Remove the Screws: étape 8, image 1 de 1
    • Remove the screws that secure the battery to the computer base.
  9. Dell Alienware 14 Wireless Mini-Card Replacement, Using the Battery Cable: étape 9, image 1 de 1
    • Using the battery cable, lift the battery and release it from the tabs on the computer base.
  10. Dell Alienware 14 Wireless Mini-Card Replacement, Turn the Computer Over: étape 10, image 1 de 1
    • Turn the computer over and open the display as far as possible.
  11. Dell Alienware 14 Wireless Mini-Card Replacement, The Power Button: étape 11, image 1 de 1
    • Press and hold the power button for five seconds to ground the system board.
    • Close the display and turn the computer over.
  12. Dell Alienware 14 Wireless Mini-Card Replacement, Align the Tabs: étape 13, image 1 de 1
    • Align the tabs on the NEW battery with the slots on the computer base.
  13. Dell Alienware 14 Wireless Mini-Card Replacement, Align the Screw Holes: étape 14, image 1 de 1
    • Align the screw holes on the battery with the screw holes on the computer base.
  14. Dell Alienware 14 Wireless Mini-Card Replacement, Replace the Screws: étape 15, image 1 de 1
    • Replace the screws that secure the battery to the computer base.
  15. Dell Alienware 14 Wireless Mini-Card Replacement, Connect the Battery Cable: étape 16, image 1 de 1
    • Connect the battery cable to the system-board connector.
  16. Dell Alienware 14 Wireless Mini-Card Replacement, Disconnect the Antenna Cables: étape 17, image 1 de 2 Dell Alienware 14 Wireless Mini-Card Replacement, Disconnect the Antenna Cables: étape 17, image 2 de 2
  17. Dell Alienware 14 Wireless Mini-Card Replacement, Remove the Screw: étape 18, image 1 de 1
    • Remove the screw that secures the wireless mini-card to the system board.
  18. Dell Alienware 14 Wireless Mini-Card Replacement, Remove the Wireless-Mini Card: étape 19, image 1 de 2 Dell Alienware 14 Wireless Mini-Card Replacement, Remove the Wireless-Mini Card: étape 19, image 2 de 2
    • Slide and remove the wireless-mini card from the system-board connector.
  19. Dell Alienware 14 Wireless Mini-Card Replacement, Align the Notch: étape 20, image 1 de 1
    • Align the notch on the NEW wireless mini-card with the tab on the system-board connector.
    • CAUTION: Use firm and even pressure to slide the wireless mini-card into place. If you use excessive force, you may damage the connector.
    • CAUTION: The connectors are keyed to ensure correct insertion. If you feel resistance, check the connectors on the wireless mini-card and on the system-board connector, and realign the wireless mini-card.
    • CAUTION: To avoid damage to the wireless mini-card, never place cables under the wireless mini-card.
  20. Dell Alienware 14 Wireless Mini-Card Replacement, Inserting the Wireless Mini-Card: étape 21, image 1 de 1
    • Insert the wireless mini-card at a 45-degree angle into the system-board connector.
  21. Dell Alienware 14 Wireless Mini-Card Replacement, Securing the Wireless Mini-Card: étape 22, image 1 de 1
    • Press the other end of the wireless mini-card down into the slot on the system board and replace the screw that secures the wireless mini-card to the system board.
  22. Dell Alienware 14 Wireless Mini-Card Replacement, Connect the Antenna Cables: étape 23, image 1 de 1
    • Connect the antenna cables to the connectors on the wireless mini-card.
Terrence15
Membre depuis le 12/18/17
79 034 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 184
