Aller au contenu principal
Dell Alienware 15 R3 Wi-Fi Card Replacement
Ce dont vous avez besoin
  1. Dell Alienware 15 R3 Wi-Fi Card Replacement, Back Case: étape 1, image 1 de 3 Dell Alienware 15 R3 Wi-Fi Card Replacement, Back Case: étape 1, image 2 de 3 Dell Alienware 15 R3 Wi-Fi Card Replacement, Back Case: étape 1, image 3 de 3
    • Before you begin, turn off the laptop and unplug the charger.
    • Flip the laptop over so that the backside is facing up.
    • Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
    • Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
  2. Dell Alienware 15 R3 Wi-Fi Card Replacement: étape 2, image 1 de 1
    • Use the opening tool to pry the back case from the computer.
    • Use the opening tool and work your way around the perimeter of the back case to gently release the clips.
    • Start from the black vent for an easier removal.
    • Lift the back case off of the laptop.
  3. Dell Alienware 15 R3 Wi-Fi Card Replacement, Cover Assembly: étape 3, image 1 de 1
    • Use a Phillips #00 screwdriver to remove two screws from the side of the laptop.
  4. Dell Alienware 15 R3 Wi-Fi Card Replacement: étape 4, image 1 de 2 Dell Alienware 15 R3 Wi-Fi Card Replacement: étape 4, image 2 de 2
    • Use an opening tool to release the four tabs from the hinge cover and gently pry it off.
  5. Dell Alienware 15 R3 Wi-Fi Card Replacement: étape 5, image 1 de 3 Dell Alienware 15 R3 Wi-Fi Card Replacement: étape 5, image 2 de 3 Dell Alienware 15 R3 Wi-Fi Card Replacement: étape 5, image 3 de 3
    • Use a Phillips #00 screwdriver to remove nine screws from the chassis.
    • Use a spudger or opening tool to remove the chassis and reveal the battery, fan, motherboard, and other components.
  6. Dell Alienware 15 R3 Wi-Fi Card Replacement, Wi-Fi Card: étape 6, image 1 de 3 Dell Alienware 15 R3 Wi-Fi Card Replacement, Wi-Fi Card: étape 6, image 2 de 3 Dell Alienware 15 R3 Wi-Fi Card Replacement, Wi-Fi Card: étape 6, image 3 de 3
    • Open the flap to reveal the Wi-Fi card.
    • Use the Phillips #00 screwdriver to remove the screw securing the Wi-Fi card.
    • Use a spudger to detach the coaxial cables from the Wi-Fi card.
    • Be careful when detaching these cable connectors from the Wi-Fi card. The base of the connectors are prone to break off.
Jake Nelson
Membre depuis le 09/22/22
584 Réputation
7 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 27
Total : 360
