Introduction
In this guide, we will show you how to remove and replace Memory Modules 1 & 2.
Pièces
Aucune pièce nécessaire.
WARNING:   Before working inside your computer, read the safety  information that shipped with your computer and follow the steps in Before Working Inside Your Computer. . After working  inside your computer, follow the instructions in After Working Inside Your Computer.
Ajouter un commentaire
Remove the screws that secure the base cover to the computer base.
  • Remove the screws that secure the base cover to the computer base.
  • Slide the base cover toward the front of the computer.
  • Lift the base cover off.
  • Align the tabs on the new base cover with the slots on the computer base
  • Slide the base cover toward the back of the computer and align the screws holes on the base cover with the screw holes on the computer base.
  • Replace the screws that secure the base cover to the computer base.
  • Remove the screws that secure the battery to the computer base.
  • Using the battery cable, lift and release the battery from the tabs on the computer base.
  • Turn the computer over and open the display.
  • Press and hold the power button for five seconds to ground the system board.
  • Slide the NEW battery under the tabs on the computer base.
  • Align the screw holes on the battery with the screw holes on the computer base.
  • Replace the screws that secure the battery to the computer base.
  • Connect the battery cable to the system board.
  • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. . After working inside your computer, follow the instructions in After Working Inside Your Computer.
  • CAUTION: To avoid data loss, do not remove the hard drive while the computer is On or in Sleep state.
  • CAUTION: Hard drives are extr emely fragile. Exercise care when handling the hard drive.
  • Remove the screws that secure the hard-drive assembly to the computer base.
  • Using the pull-tab, lift the hard-drive assembly off the computer base.
  • Disconnect the interposer from the hard drive.
  • Remove the screws that secure the hard-drive bracket to the hard drive.
  • Lift the hard-drive bracket off the hard drive.
  • Place the NEW hard drive in the hard-drive bracket.
  • Replace the screws that secure the hard-drive bracket to the hard drive.
  • Connect the interposer to the hard drive.
  • Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
  • Place the hard-drive assembly in the hard-drive bay.
  • Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  • Replace the screws that secure the hard-drive assembly to the computer base.
  • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions After Working Inside Your Computer.
  • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
  • Using the pull-tab, gently lift the hard-drive assembly.
  • Lift the latch and disconnect the hard-drive cable from the system board.
  • Lift the hard-drive assembly off the computer base.
  • Place the NEW hard drive into the hard-drive bracket.
  • Connect the interposer to the hard-drive.
  • Using your fingertips, carefully spread apart the securing clips at the sides of the memory-module connector until the memory module pops up.
  • Slide and remove the memory module from the memory-module connector.
  • Align the notch on the NEW memory module with the tab on the memory-module connector.
  • Slide the memory module into the connect or at a 45-degree angle, and press the memory module down until it clicks in place.  If you do not hear the click, remove and reinstall the memory module
  • The computer may not boot if the memory module is not installed correctly.
Terrence15
Membre depuis le 18/12/2017
69 311 Réputation
444 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
917 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 10
Total : 49
