Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
In this guide, we will be showing you how to remove and replace the Coin-Cell Battery.
Pièces
Aucune pièce spécifiée.
  1. WARNING:   Before working inside your computer, read the safety information that shipped with your  computer and follow the steps in Before     You     Begin.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
  2. Remove the screws that secure the base cover to the computer base.
    • Remove the screws that secure the base cover to the computer base.
  3. Slide the base cover towards the rear of  the computer and lift it off the computer  base.
    • Slide the base cover towards the rear of the computer and lift it off the computer base.
  4. Align the tabs on the NEW base cover with the  slots on the computer base and slide the  base cover into place.
    • Align the tabs on the NEW base cover with the slots on the computer base and slide the base cover into place.
  5. Kits pour Nintendo Switch
    Une solution rapide pour reprendre le jeu
    Acheter un kit pour Switch
  6. Replace the screws that secure the base cover to the computer base.
    • Replace the screws that secure the base cover to the computer base.
  7. WARNING: Before working inside your computer, read the safety  information that shipped with your  computer and follow the steps in Before You Begin.
    • WARNING: The battery may explode if installed incorrectly. Replace the battery only with the same or equivalent type. Discard used batteries according to the manufacturer’s instructions.
    • CAUTION: Removing the coin-cell battery resets the BIOS settings to default. It is recommended that you note the BIOS settings before removing the coin-cell battery.
    • Disconnect the coin-cell battery cable from its connector on the system board.
  8. Remove the coin-cell battery cable from the routing guides on the computer base.
    • Remove the coin-cell battery cable from the routing guides on the computer base.
  9. Pry up the coin-cell battery from  the slot on the system board.
    • Pry up the coin-cell battery from the slot on the system board.
  10. Place the NEW coin-cell battery into the slot and press gently to adhere it to the computer  base.
    • Place the NEW coin-cell battery into the slot and press gently to adhere it to the computer base.
  11. Route the coin-cell battery cable through the routing guides on the computer base.
    • Route the coin-cell battery cable through the routing guides on the computer base.
  12. Connect the coin-cell battery cable to  its connector on the system board.
    • Connect the coin-cell battery cable to its connector on the system board.
Ligne d'arrivée
darrius
Membre depuis le 26/03/2018
5 072 Réputation
30 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
21 membres
1 816 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 4
Total : 121
