Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Dell Alienware 18 Memory Module Replacement
Ce dont vous avez besoin
  1. Dell Alienware 18 Memory Module Replacement, Warning: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
  2. Dell Alienware 18 Memory Module Replacement, Removing the Memory Module: étape 2, image 1 de 1
    • To remove memory module(s) from connectors DIMM3 and DIMM4, go to step 3.
    • To remove memory module(s) from connectors DIMM1 and DIMM2: Remove the palm rest. See"Removing the Palm Rest" on page 39.
  3. Dell Alienware 18 Memory Module Replacement, Popping up the Memory Module: étape 3, image 1 de 1
    • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory module securing clips.
    • Using your fingertips, spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
  4. Dell Alienware 18 Memory Module Replacement, Removing the Memory Module: étape 4, image 1 de 1
    • Remove the memory module from the memory-module connector.
  5. Dell Alienware 18 Memory Module Replacement, Replacing the Memory Module: étape 5, image 1 de 1
    • Align the notch on the NEW memory module with the tab on the memory-module connector.
  6. Dell Alienware 18 Memory Module Replacement, Securing the Memory Module: étape 6, image 1 de 1
    • Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
Ligne d'arrivée
2 autres ont terminé cette réparation.
darrius
Membre depuis le 03/26/18
5 213 Réputation
30 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
45 membres
1 999 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 32
30 derniers jours : 80
Total : 714
