Aller au contenu principal
Dell Alienware M11x R3 2.5" Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Alienware M11x R3  2.5" Hard Drive Replacement, Lower Case: étape 1, image 1 de 3 Dell Alienware M11x R3  2.5" Hard Drive Replacement, Lower Case: étape 1, image 2 de 3 Dell Alienware M11x R3  2.5" Hard Drive Replacement, Lower Case: étape 1, image 3 de 3
    • Loosen the eight retaining screws on the base of the computer with a small Phillips screwdriver.
    • The screws have retaining washers to hold them in place, so you don't have to remove them from the base plate.
    • Remove the bottom cover from the laptop.
  2. Dell Alienware M11x R3  2.5" Hard Drive Replacement, Hard Drive: étape 2, image 1 de 1
    • Remove the three screws attaching the hard drive tray to the laptop.
  3. Dell Alienware M11x R3  2.5" Hard Drive Replacement: étape 3, image 1 de 1
    • Grasp the plastic tab provided, and gently pull up. This will unplug the drive from the laptop.
  4. Dell Alienware M11x R3  2.5" Hard Drive Replacement: étape 4, image 1 de 2 Dell Alienware M11x R3  2.5" Hard Drive Replacement: étape 4, image 2 de 2
    • On both sides of the cage, there are two screws you have to unscrew to be able to remove the SSD.
  5. Dell Alienware M11x R3  2.5" Hard Drive Replacement: étape 5, image 1 de 2 Dell Alienware M11x R3  2.5" Hard Drive Replacement: étape 5, image 2 de 2
    • Finally, remove the L connector for the hard drive. You will need to put this on your new hard drive.
    • Make sure that the SSD you bought to replace this one has the same connections. I.e. able to connect to a SATA cord.
Richard Maurice
Membre depuis le 03/08/17
534 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G7, Botvin Spring 2017 Membre de l'équipe UMass Dartmouth, Team S3-G7, Botvin Spring 2017
UMASSD-BOTVIN-S17S3G7
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 18
Total : 1,566
