Aller au contenu principal
Dell Alienware M11x R3 Keyboard Replacement
Ce dont vous avez besoin
  1. Dell Alienware M11x R3 Keyboard Replacement, Lower Case: étape 1, image 1 de 3 Dell Alienware M11x R3 Keyboard Replacement, Lower Case: étape 1, image 2 de 3 Dell Alienware M11x R3 Keyboard Replacement, Lower Case: étape 1, image 3 de 3
    • Loosen the eight retaining screws on the base of the computer with a small Phillips screwdriver.
    • The screws have retaining washers to hold them in place, so you don't have to remove them from the base plate.
    • Remove the bottom cover from the laptop.
  2. Dell Alienware M11x R3 Keyboard Replacement, Keyboard: étape 2, image 1 de 1
    • Unscrew the two circled screws holding the battery in place. These screws have retaining washers, so they won't completely detach from the device.
  3. Dell Alienware M11x R3 Keyboard Replacement: étape 3, image 1 de 2 Dell Alienware M11x R3 Keyboard Replacement: étape 3, image 2 de 2
    • Next, unplug the battery cable (PD12) from the motherboard by gently pulling up.
  4. Dell Alienware M11x R3 Keyboard Replacement: étape 4, image 1 de 1
    • Now, remove the battery by gently pulling on the tab located between the two screws. The battery will pivot, and you will be able to completely detach the battery from the device.
  5. Dell Alienware M11x R3 Keyboard Replacement: étape 5, image 1 de 2 Dell Alienware M11x R3 Keyboard Replacement: étape 5, image 2 de 2
    • Once the battery is removed, take out the two screws circled. These screws are labeled "M2x3 K" by engravings in the frame located next to their corresponding holes.
    • These screws will be completely removed. Keep them somewhere safe.
  6. Dell Alienware M11x R3 Keyboard Replacement: étape 6, image 1 de 3 Dell Alienware M11x R3 Keyboard Replacement: étape 6, image 2 de 3 Dell Alienware M11x R3 Keyboard Replacement: étape 6, image 3 de 3
    • Now, flip the computer back over. Above the "DELETE" key on the edge of the computer is a small indent. Here you will use the spudger to pry this plastic piece up.
  7. Dell Alienware M11x R3 Keyboard Replacement: étape 7, image 1 de 1
    • Push the monitor back as far as the hinges will allow.
    • Continue to pry the plastic piece off along the top of the keyboard. Remove this piece.
  8. Dell Alienware M11x R3 Keyboard Replacement: étape 8, image 1 de 1
    • Now remove the two screws located directly above the F3 key and the PAUSE key.
    • These screws will also be completely removed, so keep them in a safe place.
  9. Dell Alienware M11x R3 Keyboard Replacement: étape 9, image 1 de 2 Dell Alienware M11x R3 Keyboard Replacement: étape 9, image 2 de 2
    • With both screws removed, gently lift up on the keyboard, and slide it towards the monitor. It will come out.
    • Caution: Do not tug too hard on the keyboard, as it has two fragile connection ribbons underneath that you do not want to tear.
  10. Dell Alienware M11x R3 Keyboard Replacement: étape 10, image 1 de 3 Dell Alienware M11x R3 Keyboard Replacement: étape 10, image 2 de 3 Dell Alienware M11x R3 Keyboard Replacement: étape 10, image 3 de 3
    • Now unlock and unplug the two ribbons cables underneath the keyboard. They are held in place by black locks.
    • To unlock them, gently slide a finger nail or spudger tool under them and lift up. You need to do this for both ribbons.
    • With the old keyboard removed, you can now install your new one and reassemble the computer!
To reassemble your device, follow these instructions in reverse order while attaching the new keyboard.
Richard Maurice
Membre depuis le 03/08/17
534 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G7, Botvin Spring 2017 Membre de l'équipe UMass Dartmouth, Team S3-G7, Botvin Spring 2017
UMASSD-BOTVIN-S17S3G7
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 23
Total : 1,758
