Aller au contenu principal
Dell Alienware M11x R3 Wi-Fi Card Replacement
Ce dont vous avez besoin
  1. Dell Alienware M11x R3 Wi-Fi Card Replacement, Lower Case: étape 1, image 1 de 3 Dell Alienware M11x R3 Wi-Fi Card Replacement, Lower Case: étape 1, image 2 de 3 Dell Alienware M11x R3 Wi-Fi Card Replacement, Lower Case: étape 1, image 3 de 3
    • Loosen the eight retaining screws on the base of the computer with a small Phillips screwdriver.
    • The screws have retaining washers to hold them in place, so you don't have to remove them from the base plate.
    • Remove the bottom cover from the laptop.
  2. Dell Alienware M11x R3 Wi-Fi Card Replacement, Wi-Fi Card: étape 2, image 1 de 2 Dell Alienware M11x R3 Wi-Fi Card Replacement, Wi-Fi Card: étape 2, image 2 de 2
    • Your Wi-Fi card will have two coaxial cable wires connected to it.
    • Gently pull up the wires to disconnect them from the Wi-Fi card.
    • Be careful when you pull the wires. Pulling them hard or yanking them hard might cause damage to the wire or the Wi-Fi card.
  3. Dell Alienware M11x R3 Wi-Fi Card Replacement: étape 3, image 1 de 1
    • Once the wires are removed, use an appropriate screwdriver to remove the screws holding down the Wi-Fi card.
  4. Dell Alienware M11x R3 Wi-Fi Card Replacement: étape 4, image 1 de 2 Dell Alienware M11x R3 Wi-Fi Card Replacement: étape 4, image 2 de 2
    • When the Wi-Fi card pop ups, slide it out of the socket.
    • Any mishandling of the Wi-Fi card will cause serious damage to it, so please be careful with it.
Richard Maurice
Membre depuis le 03/08/17
534 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G7, Botvin Spring 2017 Membre de l'équipe UMass Dartmouth, Team S3-G7, Botvin Spring 2017
UMASSD-BOTVIN-S17S3G7
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 15
Total : 689
