Aller au contenu principal
Dell Alienware M17x R3 Display Assembly Replacement
Ce dont vous avez besoin
  1. Dell Alienware M17x R3 Display Assembly Replacement, Loosen the Screws: étape 1, image 1 de 1
    • Loosen the two captive screws that secure the display cable to the system board.
  2. Dell Alienware M17x R3 Display Assembly Replacement, Disconnecting the Display Cable: étape 2, image 1 de 1
    • Using the pull-tab, pull the display cable to disconnect the display cable from the connector on the system board.
  3. Dell Alienware M17x R3 Display Assembly Replacement, Disconnecting the Camera Cable: étape 3, image 1 de 1
    • Disconnect the camera cable and infrared cable from the respective system board connectors.
  4. Dell Alienware M17x R3 Display Assembly Replacement, Remove the Cables: étape 4, image 1 de 2 Dell Alienware M17x R3 Display Assembly Replacement, Remove the Cables: étape 4, image 2 de 2
    • Note the routing of the display cable, camera cable, infrared cable, wirelessHD card cable, Mini-Card antenna cables and remove the cables from the routing guides on the palm rest assembly.
  5. Dell Alienware M17x R3 Display Assembly Replacement, Remove the Screws: étape 5, image 1 de 1
    • Remove the six screws that secure the display assembly to the computer base.
  6. Dell Alienware M17x R3 Display Assembly Replacement, Removing the Display Assembly: étape 6, image 1 de 1
    • Lift the display assembly off the computer.
  7. Dell Alienware M17x R3 Display Assembly Replacement, Securing the Display Assembly: étape 7, image 1 de 2 Dell Alienware M17x R3 Display Assembly Replacement, Securing the Display Assembly: étape 7, image 2 de 2
    • Place the NEW display assembly in position and replace the six screws that secure the display assembly to the computer base.
  8. Dell Alienware M17x R3 Display Assembly Replacement, Route the Cables: étape 8, image 1 de 2 Dell Alienware M17x R3 Display Assembly Replacement, Route the Cables: étape 8, image 2 de 2
    • Route the display cable, camera cable, infrared cable, wirelessHD card cable, and Mini-Card antenna cables through the routing guides on the palm rest assembly.
  9. Dell Alienware M17x R3 Display Assembly Replacement, Connecting the Display Cable: étape 9, image 1 de 1
    • Connect the display cable to the connector on the system board.
  10. Dell Alienware M17x R3 Display Assembly Replacement, Tighten the Screws: étape 10, image 1 de 1
    • Tighten the two captive screws that secure the display cable to the system board.
  11. Dell Alienware M17x R3 Display Assembly Replacement, Connect the Camera Cable: étape 11, image 1 de 1
    • Connect the camera cable and infrared cable to the respective system board connectors.
Terrence15
Membre depuis le 12/18/17
79 121 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 13
Total : 1,089
