Aller au contenu principal
Dell Alienware M18x R2 Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Alienware M18x R2 Hard Drive Replacement, Lifting the Connector Latch: étape 1, image 1 de 2 Dell Alienware M18x R2 Hard Drive Replacement, Lifting the Connector Latch: étape 1, image 2 de 2
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive
    • Lift the connector latch that secures the hard-drive cable to the connector on the system board, and then disconnect the hard-drive cable from the connector on the system board.
  2. Dell Alienware M18x R2 Hard Drive Replacement, Lifting the Hard-Drive Assembly: étape 2, image 1 de 1
    • Using the pull-tab, lift the hard-drive assembly out of the computer base.
  3. Dell Alienware M18x R2 Hard Drive Replacement, Disconnecting the Interposer: étape 3, image 1 de 2 Dell Alienware M18x R2 Hard Drive Replacement, Disconnecting the Interposer: étape 3, image 2 de 2
    • Disconnect the interposer from the hard drives.
  4. Dell Alienware M18x R2 Hard Drive Replacement, Remove the Screws: étape 4, image 1 de 1
    • Remove the screws that secure the hard drive(s) and slide the hard drive(s) out of the hard-drive bracket.
  5. Dell Alienware M18x R2 Hard Drive Replacement, Placing the Hard Drive: étape 5, image 1 de 1
    • Place the NEW primary hard drive (HDD 0) in the hard-drive bracket.
  6. Dell Alienware M18x R2 Hard Drive Replacement, Sliding the Hard Drives: étape 6, image 1 de 1
    • If applicable, slide the secondary and tertiary hard drive(s) into the hard-drive bracket.
  7. Dell Alienware M18x R2 Hard Drive Replacement, Replace the Screws: étape 7, image 1 de 1
    • Replace the screws that secure the primary hard drive (HDD 0).
  8. Dell Alienware M18x R2 Hard Drive Replacement, Connecting the Interposer: étape 8, image 1 de 1
    • If applicable, replace the screws that secure the secondary hard drive (HDD 1) and tertiary hard drive (HDD 2) to the hard-drive bracket.
    • Connect the interposer to the hard drive(s).
  9. Dell Alienware M18x R2 Hard Drive Replacement, Placing the Hard-Drive Assembly: étape 9, image 1 de 1
    • Place the hard-drive assembly in the computer base.
  10. Dell Alienware M18x R2 Hard Drive Replacement, Tighten the Captive Screws: étape 10, image 1 de 1
    • Tighten the captive screws that secure the hard-drive assembly to the computer base.
  11. Dell Alienware M18x R2 Hard Drive Replacement, Sliding the Hard-Drive Cable: étape 11, image 1 de 1
    • Slide the hard-drive cable into the connector on the system board and press down on the connector latch to secure the cable.
Terrence15
Membre depuis le 12/18/17
79 121 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 20
Total : 1,006
