Introduction
In this guide, we will show you how to remove and replace the Memory Modules.
WARNING: Before working inside your computer, read the safety  information that shipped with your  computer and follow the steps in Before You Begin.
  • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
  • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory module securing clips.
  • Using your fingertips, spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
Ajouter un commentaire
Remove the memory module from the memory-module connector.
  • Remove the memory module from the memory-module connector.
  • NOTE: If you need to install memory modules in two connectors, install a memory module in the lower connector before you install a memory module in the upper connector.
  • Align the notch on the NEW memory module with the tab on the memory-module connector.
  • Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
Terrence15
Membre depuis le 18/12/2017
69 301 Réputation
444 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
917 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 13
