Aller au contenu principal
Dell Chromebook 11 CB1C13 Battery Replacement
Ce dont vous avez besoin
  1. Dell Chromebook 11 CB1C13 Battery Replacement, Battery: étape 1, image 1 de 3 Dell Chromebook 11 CB1C13 Battery Replacement, Battery: étape 1, image 2 de 3 Dell Chromebook 11 CB1C13 Battery Replacement, Battery: étape 1, image 3 de 3
    • Make sure that device is fully powered down before attempting to open the back case.
    • Remove all seven 8mm Philips #0 screws from the back case with a Philips #0 screwdriver.
    • Once all seven screws are removed, you can pry the case off using your fingers or a plastic opening tool.
  2. Dell Chromebook 11 CB1C13 Battery Replacement: étape 2, image 1 de 2 Dell Chromebook 11 CB1C13 Battery Replacement: étape 2, image 2 de 2
    • Use a Phillips #0 screwdriver to unscrew the four 8 mm screws that secure the battery.
  3. Dell Chromebook 11 CB1C13 Battery Replacement: étape 3, image 1 de 2 Dell Chromebook 11 CB1C13 Battery Replacement: étape 3, image 2 de 2
    • Use a plastic spudger to push the bundled cable connector free in the same direction as the individual wires are running.
    • You can use your fingers to help pull the cable free. Pull evenly on the full width of the cable so that no individual wires are overly strained.
    • Proceed to gently remove the battery from the back panel.
To replace your Dell Chromebook 11 battery, follow these instructions in order.
2 autres ont terminé cette réparation.
Jerry Geffrard
Membre depuis le 03/25/15
334 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G6, Bailey Fall 2017 Membre de l'équipe UMass Dartmouth, Team S3-G6, Bailey Fall 2017
UMASSD-BAILEY-F17S3G6
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 19
30 derniers jours : 31
Total : 1,430
