Aller au contenu principal
Dell Chromebook 11 CB1C13 DC Jack Cable Replacement
Ce dont vous avez besoin
    • Get your trusty Phillips screwdriver and unscrew the Phillips Screws and put them somewhere safe.
    • Then pry open and remove bottom case cover.
    • Now what you want to do is find two screws protecting the battery. Unscrew them and put them somewhere safe.
    • Remove the cable from the battery and put it somewhere safe.
    • Now, find the DC Jack Cable. It should be in the top right corner.
    • To remove the DC Jack Cable, use your fingernails and try to remove it. Once out, put it somewhere safe.
    • To put in a new one, insert it with a lot of pressure and it should be secure.
To reassemble your device, follow steps 1 and 2 in reverse order.
EmreTech
Membre depuis le 05/12/18
199 Réputation
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 19
30 derniers jours : 21
Total : 130
