Aller au contenu principal
Dell Chromebook 11 CB1C13 Fan Replacement
Ce dont vous avez besoin
  1. Dell Chromebook 11 CB1C13 Fan Replacement, Back Panel: étape 1, image 1 de 3 Dell Chromebook 11 CB1C13 Fan Replacement, Back Panel: étape 1, image 2 de 3 Dell Chromebook 11 CB1C13 Fan Replacement, Back Panel: étape 1, image 3 de 3
    • Make sure that device is fully powered down before attempting to open the back case.
    • Remove all seven 8 mm Philips #0 screws from the back case with a Philips #0 screwdriver.
    • Once all seven screws are removed, you can pry the case off using your fingers or a plastic opening tool.
  2. Dell Chromebook 11 CB1C13 Fan Replacement, Fan: étape 2, image 1 de 3 Dell Chromebook 11 CB1C13 Fan Replacement, Fan: étape 2, image 2 de 3 Dell Chromebook 11 CB1C13 Fan Replacement, Fan: étape 2, image 3 de 3
    • Locate the two wires that connect the fan to the device. One black, and one white.
    • Move these wires off of the fan by gently pulling on them.
    • Locate the two 8mm Philips #0 screws that connect the fan to the device.
    • Remove these screws using a Philips #0 screwdriver.
  3. Dell Chromebook 11 CB1C13 Fan Replacement: étape 3, image 1 de 3 Dell Chromebook 11 CB1C13 Fan Replacement: étape 3, image 2 de 3 Dell Chromebook 11 CB1C13 Fan Replacement: étape 3, image 3 de 3
    • The fan is connected by a 5 pin port. Remove this by gently prying out the fan's port using your fingers or a plastic prying tool.
    • The pin port can be very delicate. Any major bending or twisting can cause permanent damage to the port, and may leave it unable to work.
Bryan Allen
Membre depuis le 10/20/17
272 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G6, Bailey Fall 2017 Membre de l'équipe UMass Dartmouth, Team S3-G6, Bailey Fall 2017
UMASSD-BAILEY-F17S3G6
3 membres
7 tutoriels rédigés
Un commentaire
Ram?
Can i change the ram?
flip - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 13
Total : 950
