Aller au contenu principal
Dell Chromebook 11-3120 Battery Replacement
Ce dont vous avez besoin
  1. Dell Chromebook 11-3120 Battery Replacement, Remove screws: étape 1, image 1 de 1
    • Flip the device over so the bottom is facing up
    • Remove the 7 visible Philips screws from the device's bottom cover
  2. Dell Chromebook 11-3120 Battery Replacement: étape 2, image 1 de 2 Dell Chromebook 11-3120 Battery Replacement: étape 2, image 2 de 2
    • Insert a thin prying tool into the front (facing the user) corner between the rubber bumper and the plastic case to pop several latches.
    • Starting from the partially-opened corner, pull the case away from the device in a hinging motion. I rotated the computer so that the opened corner faced me in the image.
  3. Dell Chromebook 11-3120 Battery Replacement, Unplug battery connector: étape 3, image 1 de 1
    • Unplug the battery connector from the motherboard
  4. Dell Chromebook 11-3120 Battery Replacement, Remove screws: étape 4, image 1 de 1
    • Remove the two silver screws that hold the battery to the case
    • Lift the battery straight out of the case and place it in a safe, static-free place
May D
Membre depuis le 12/08/17
2 659 Réputation
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 438
