Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
Computer batteries can sometimes become weaker over time, losing charge and making it difficult to properly use your device. If your battery is not functioning correctly anymore, then follow this guide to remove/replace the battery in a Dell Chromebook 13-7310.
  1. Remove the eleven 3mm Phillips #1 screws. Remove the eleven 3mm Phillips #1 screws.
    • Remove the eleven 3mm Phillips #1 screws.
  2. Use a plastic opening tool to gently remove the back panel.
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
    • Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
  4. Remove the four 2mm screws on the sides of the battery.
    • Remove the four 2mm screws on the sides of the battery.
  5. To remove the battery, lift up on one side to get your fingers underneath and lift away.
    • To remove the battery, lift up on one side to get your fingers underneath and lift away.
Congratulations! You have successfully removed the battery of your Dell Chromebook 13-7310. To reassemble your device, follow these instructions in reverse order.
2 autre(s) ont terminé cette réparation.
Caleb S Whitener
Membre depuis le 08/09/2017
225 Réputation
2 tutoriels rédigés
Équipe
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 840
