Aller au contenu principal
Dell Chromebook 13-7310 Cooling Fan Replacement
Ce dont vous avez besoin
  1. Dell Chromebook 13-7310 Cooling Fan Replacement, Back Cover: étape 1, image 1 de 2 Dell Chromebook 13-7310 Cooling Fan Replacement, Back Cover: étape 1, image 2 de 2
    • Remove the eleven 3mm Phillips #1 screws.
  2. Dell Chromebook 13-7310 Cooling Fan Replacement: étape 2, image 1 de 1
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Dell Chromebook 13-7310 Cooling Fan Replacement, Cooling Fan: étape 3, image 1 de 2 Dell Chromebook 13-7310 Cooling Fan Replacement, Cooling Fan: étape 3, image 2 de 2
    • Using the #1 Philips screwdriver, remove the two, 2mm screws securing the fan assembly.
  4. Dell Chromebook 13-7310 Cooling Fan Replacement: étape 4, image 1 de 2 Dell Chromebook 13-7310 Cooling Fan Replacement: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    • Using your fingernails, pull the cooling fan cables loose from the motherboard.
    • We have the tweezers pictured to allow for a clear view of components. DO NOT use the tweezers to remove the cables, they could be damaged in the process.
    • Finally, lift the fan assembly away from the computer.
Congratulations! You have successfully removed the cooling fan of your Dell Chromebook 13-7310. To reassemble your device, follow these instructions in reverse order.
Alec Thomas
Membre depuis le 09/08/17
120 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 519
