Aller au contenu principal
Dell Chromebook 13-7310 IO Board Replacement
Ce dont vous avez besoin
  1. Dell Chromebook 13-7310 IO Board Replacement, Back Cover: étape 1, image 1 de 2 Dell Chromebook 13-7310 IO Board Replacement, Back Cover: étape 1, image 2 de 2
    • Remove the eleven 3mm Phillips #1 screws.
  2. Dell Chromebook 13-7310 IO Board Replacement: étape 2, image 1 de 1
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Dell Chromebook 13-7310 IO Board Replacement, Battery: étape 3, image 1 de 1
    • Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
  4. Dell Chromebook 13-7310 IO Board Replacement: étape 4, image 1 de 1
    • Remove the four 2mm screws on the sides of the battery.
  5. Dell Chromebook 13-7310 IO Board Replacement: étape 5, image 1 de 1
    • To remove the battery, lift up on one side to get your fingers underneath and lift away.
  6. Dell Chromebook 13-7310 IO Board Replacement, IO Board: étape 6, image 1 de 1
    • Remove the single 2mm screw securing the IO board to the laptop.
  7. Dell Chromebook 13-7310 IO Board Replacement: étape 7, image 1 de 1
    • Pull up on the connector to release the IO board cable from the motherboard.
    • It may be easier to pull from the blue tab.
  8. Dell Chromebook 13-7310 IO Board Replacement: étape 8, image 1 de 1
    • Remove the IO board.
Damon
Membre depuis le 11/01/18
181 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S5-G1, Gulbrandsen Fall 2018 Membre de l'équipe UMass Dartmouth, Team S5-G1, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G1
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 9
Total : 320
