Aller au contenu principal
Dell Chromebook 13-7310 Motherboard Replacement
Ce dont vous avez besoin
  1. Dell Chromebook 13-7310 Motherboard Replacement, Back Cover: étape 1, image 1 de 2 Dell Chromebook 13-7310 Motherboard Replacement, Back Cover: étape 1, image 2 de 2
    • Remove the eleven 3mm Phillips #1 screws.
  2. Dell Chromebook 13-7310 Motherboard Replacement: étape 2, image 1 de 1
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Dell Chromebook 13-7310 Motherboard Replacement, Battery: étape 3, image 1 de 1
    • Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
  4. Dell Chromebook 13-7310 Motherboard Replacement: étape 4, image 1 de 1
    • Remove the four 2mm screws on the sides of the battery.
  5. Dell Chromebook 13-7310 Motherboard Replacement: étape 5, image 1 de 1
    • To remove the battery, lift up on one side to get your fingers underneath and lift away.
  6. Dell Chromebook 13-7310 Motherboard Replacement, Network Card: étape 6, image 1 de 2 Dell Chromebook 13-7310 Motherboard Replacement, Network Card: étape 6, image 2 de 2
    • Use #1 Phillips screwdriver to remove the 1mm screw in the network card.
  7. Dell Chromebook 13-7310 Motherboard Replacement: étape 7, image 1 de 1
    • Disconnect the network card from motherboard socket.
  8. Dell Chromebook 13-7310 Motherboard Replacement: étape 8, image 1 de 1
    • Disconnect 2 cable connectors from network card.
    • If the cables are stuck, continue to gently wiggle them until they disconnect.
  9. Dell Chromebook 13-7310 Motherboard Replacement, Motherboard: étape 9, image 1 de 1
    • Gently pull to unplug fan connector.
  10. Dell Chromebook 13-7310 Motherboard Replacement: étape 10, image 1 de 2 Dell Chromebook 13-7310 Motherboard Replacement: étape 10, image 2 de 2
    • Remove 4 screws securing heat sink.
  11. Dell Chromebook 13-7310 Motherboard Replacement: étape 11, image 1 de 1
    • Lift away heat sink.
  12. Dell Chromebook 13-7310 Motherboard Replacement: étape 12, image 1 de 1
    • Remove the eight 2mm screws securing the motherboard in place.
  13. Dell Chromebook 13-7310 Motherboard Replacement: étape 13, image 1 de 1
    • Release cable for the LED charging indicator by pulling up on connector.
  14. Dell Chromebook 13-7310 Motherboard Replacement: étape 14, image 1 de 1
    • Gently remove the cable.
  15. Dell Chromebook 13-7310 Motherboard Replacement: étape 15, image 1 de 1
    • Pull up on connector tab to release IO board cable.
  16. Dell Chromebook 13-7310 Motherboard Replacement: étape 16, image 1 de 2 Dell Chromebook 13-7310 Motherboard Replacement: étape 16, image 2 de 2
    • Pull up on connector tab to release touchpad cable.
  17. Dell Chromebook 13-7310 Motherboard Replacement: étape 17, image 1 de 1
    • Release the keyboard backlight cable.
  18. Dell Chromebook 13-7310 Motherboard Replacement: étape 18, image 1 de 2 Dell Chromebook 13-7310 Motherboard Replacement: étape 18, image 2 de 2
    • Release the keyboard cable.
    • If taped to the motherboard, gently peel it off.
  19. Dell Chromebook 13-7310 Motherboard Replacement: étape 19, image 1 de 1
    • Release eDP cable.
  20. Dell Chromebook 13-7310 Motherboard Replacement: étape 20, image 1 de 1
    • Release dc-in cable.
  21. Dell Chromebook 13-7310 Motherboard Replacement: étape 21, image 1 de 1
    • Gently lift up the motherboard to remove it.
Brett Raymond
Membre depuis le 11/01/18
469 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team S5-G1, Gulbrandsen Fall 2018 Membre de l'équipe UMass Dartmouth, Team S5-G1, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G1
3 membres
5 tutoriels rédigés
Un commentaire
Is it possible to swap the non-touch matte display and the glossy touchscreen on two Dell Chromebook 13 7310?
Jeremy Ryan Terrence - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 872
