Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
A damaged motherboard is a serious issue and can be a hassle to fix, but it doesn't have to be! By following the quick and easy motherboard replacement guide you can have your Chromebook working again in no time!
  1. Remove the eleven 3mm Phillips #1 screws. Remove the eleven 3mm Phillips #1 screws.
    • Remove the eleven 3mm Phillips #1 screws.
  2. Use a plastic opening tool to gently remove the back panel.
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
    • Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
  4. Remove the four 2mm screws on the sides of the battery.
    • Remove the four 2mm screws on the sides of the battery.
  5. To remove the battery, lift up on one side to get your fingers underneath and lift away.
    • To remove the battery, lift up on one side to get your fingers underneath and lift away.
  6. Use #1 Phillips screwdriver to remove the 1mm screw in the network card. Use #1 Phillips screwdriver to remove the 1mm screw in the network card.
    • Use #1 Phillips screwdriver to remove the 1mm screw in the network card.
  7. Disconnect the network card from motherboard socket.
    • Disconnect the network card from motherboard socket.
  8. Disconnect 2 cable connectors from network card.
    • Disconnect 2 cable connectors from network card.
    • If the cables are stuck, continue to gently wiggle them until they disconnect.
  9. Gently pull to unplug fan connector.
    • Gently pull to unplug fan connector.
  10. Remove 4 screws securing heat sink. Remove 4 screws securing heat sink.
    • Remove 4 screws securing heat sink.
  11. Lift away heat sink.
    • Lift away heat sink.
  12. Remove the eight 2mm screws securing the motherboard in place.
    • Remove the eight 2mm screws securing the motherboard in place.
  13. Release cable for the LED charging indicator by pulling up on connector.
    • Release cable for the LED charging indicator by pulling up on connector.
  14. Gently remove the cable.
    • Gently remove the cable.
  15. Pull up on connector tab to release IO board cable.
    • Pull up on connector tab to release IO board cable.
  16. Pull up on connector tab to release touchpad cable. Pull up on connector tab to release touchpad cable.
    • Pull up on connector tab to release touchpad cable.
  17. Release the keyboard backlight cable.
    • Release the keyboard backlight cable.
  18. Release the keyboard cable. If taped to the motherboard, gently peel it off.
    • Release the keyboard cable.
    • If taped to the motherboard, gently peel it off.
  19. Release eDP cable.
    • Release eDP cable.
  20. Release dc-in cable.
    • Release dc-in cable.
  21. Gently lift up the motherboard to remove it.
    • Gently lift up the motherboard to remove it.
Brett Raymond
Membre depuis le 01/11/2018
445 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team S5-G1, Gulbrandsen Fall 2018 Membre de l'équipe UMass Dartmouth, Team S5-G1, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G1
3 membres
5 tutoriels rédigés
Is it possible to swap the non-touch matte display and the glossy touchscreen on two Dell Chromebook 13 7310?
Jeremy Ryan Terrence - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 11
Total : 529
