Aller au contenu principal
Dell Chromebook 3100 2-in-1 Display Replacement
Ce dont vous avez besoin
  1. Dell Chromebook 3100 2-in-1 Display Replacement, Back Cover: étape 1, image 1 de 2 Dell Chromebook 3100 2-in-1 Display Replacement, Back Cover: étape 1, image 2 de 2
    • Using a Phillips #1 screwdriver, remove all nine of the 5 mm screws from the back cover.
  2. Dell Chromebook 3100 2-in-1 Display Replacement: étape 2, image 1 de 2 Dell Chromebook 3100 2-in-1 Display Replacement: étape 2, image 2 de 2
    • Use the opening tool to pry the back cover off of the device.
  3. Dell Chromebook 3100 2-in-1 Display Replacement, Battery: étape 3, image 1 de 2 Dell Chromebook 3100 2-in-1 Display Replacement, Battery: étape 3, image 2 de 2
    • Disconnect the battery cable from the connector on the system board.
  4. Dell Chromebook 3100 2-in-1 Display Replacement: étape 4, image 1 de 3 Dell Chromebook 3100 2-in-1 Display Replacement: étape 4, image 2 de 3 Dell Chromebook 3100 2-in-1 Display Replacement: étape 4, image 3 de 3
    • Using a Phillips #1 screwdriver, remove the three 4 mm screws that secure the battery.
    • Remove the adhesive tape that secures the battery in place.
  5. Dell Chromebook 3100 2-in-1 Display Replacement: étape 5, image 1 de 2 Dell Chromebook 3100 2-in-1 Display Replacement: étape 5, image 2 de 2
    • Carefully remove the battery from the device.
  6. Dell Chromebook 3100 2-in-1 Display Replacement, Display: étape 6, image 1 de 2 Dell Chromebook 3100 2-in-1 Display Replacement, Display: étape 6, image 2 de 2
    • Remove the single 3 mm screw that secures the WLAN bracket to the system board using a Phillips #1 screwdriver.
    • Lift the WLAN bracket from the system board.
    • After lifting the bracket, carefully unplug the two coaxial cables.
  7. Dell Chromebook 3100 2-in-1 Display Replacement: étape 7, image 1 de 1
    • Remove the single 4 mm screw that secures the eDP bracket to the motherboard using a Phillips #1 screwdriver.
    • Remove the eDP bracket.
  8. Dell Chromebook 3100 2-in-1 Display Replacement: étape 8, image 1 de 2 Dell Chromebook 3100 2-in-1 Display Replacement: étape 8, image 2 de 2
    • Disconnect the display cable from the motherboard by using a plastic opening pick.
  9. Dell Chromebook 3100 2-in-1 Display Replacement: étape 9, image 1 de 1
    • Open the system to 180 degrees and place the computer on a flat surface, with the display hinges facing up.
  10. Dell Chromebook 3100 2-in-1 Display Replacement: étape 10, image 1 de 3 Dell Chromebook 3100 2-in-1 Display Replacement: étape 10, image 2 de 3 Dell Chromebook 3100 2-in-1 Display Replacement: étape 10, image 3 de 3
    • Remove the three (on both hinges) 5 mm display hinge bracket screws that secure the display assembly to the system using a Phillips #1 screwdriver.
  11. Dell Chromebook 3100 2-in-1 Display Replacement: étape 11, image 1 de 1
    • Remove the display assembly from the system.
  12. Dell Chromebook 3100 2-in-1 Display Replacement: étape 12, image 1 de 2 Dell Chromebook 3100 2-in-1 Display Replacement: étape 12, image 2 de 2
    • Use the opening tool to open the display panel starting from the pry points located above the left and right hinges.
    • Work your way around, through the left and right side of the panel, and carefully flip the display panel over.
  13. Dell Chromebook 3100 2-in-1 Display Replacement: étape 13, image 1 de 2 Dell Chromebook 3100 2-in-1 Display Replacement: étape 13, image 2 de 2
    • Peel back the adhesive tape securing the display cable on the back of the display panel and separate the display.
M Ali
Membre depuis le 11/03/21
313 Réputation
2 tutoriels rédigés
Équipe
Gateway, Team 1-1, Pee Fall 2021 Membre de l'équipe Gateway, Team 1-1, Pee Fall 2021
GCC-PEE-F21S1G1
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 30
30 derniers jours : 54
Total : 2,006
