Aller au contenu principal
Dell Chromebook 3100 2-in-1 Keyboard Replacement
Ce dont vous avez besoin
  1. Dell Chromebook 3100 2-in-1 Keyboard Replacement, Keyboard: étape 1, image 1 de 1
    • Using a phillips screw driver (PH1) remove the 9 (M2.5x4) screws holding the back cover
  2. Dell Chromebook 3100 2-in-1 Keyboard Replacement: étape 2, image 1 de 1
    • Pry the back cover off the laptop.
  3. Dell Chromebook 3100 2-in-1 Keyboard Replacement: étape 3, image 1 de 1
    • Unplug the battery.
  4. Dell Chromebook 3100 2-in-1 Keyboard Replacement: étape 4, image 1 de 1
    • Slide the black clips towards the battery to release the ribbon. Lift the ribbon out and unplug the keyboard cable.
  5. Dell Chromebook 3100 2-in-1 Keyboard Replacement: étape 5, image 1 de 3 Dell Chromebook 3100 2-in-1 Keyboard Replacement: étape 5, image 2 de 3 Dell Chromebook 3100 2-in-1 Keyboard Replacement: étape 5, image 3 de 3
    • Turn the device over. Then, using a jimmy, firmly press between the keyboard and the laptop frame.
    • Repeat this process along both sides of the laptop and the bottom of the keyboard.
  6. Dell Chromebook 3100 2-in-1 Keyboard Replacement: étape 6, image 1 de 1
    • Once the three sides have been pried open, lift the keyboard slightly and pull towards you.
ot moya
Membre depuis le 11/09/23
481 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team 3-2, Harley Fall 2023 Membre de l'équipe IUPUI, Team 3-2, Harley Fall 2023
IUPUI-HARLEY-F23S3G2
3 membres
3 tutoriels rédigés
Un commentaire
In case you were thinking about trying this without removing the bottom case, don't be like me. The center two screws on the bottom case, screw into the keyboard and the flex cable is not accessible from the under the keyboard. All steps in this guide are necessary. 🙃
Collin - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 22
Total : 426
