Aller au contenu principal
Dell Chromebook 3100 2-in-1 Motherboard Replacement
Ce dont vous avez besoin
  1. Dell Chromebook 3100 2-in-1 Motherboard Replacement, Back Cover: étape 1, image 1 de 2 Dell Chromebook 3100 2-in-1 Motherboard Replacement, Back Cover: étape 1, image 2 de 2
    • Using a Phillips #1 screwdriver, remove all nine of the 5 mm screws from the back cover.
  2. Dell Chromebook 3100 2-in-1 Motherboard Replacement: étape 2, image 1 de 2 Dell Chromebook 3100 2-in-1 Motherboard Replacement: étape 2, image 2 de 2
    • Use the opening tool to pry the back cover off of the device.
  3. Dell Chromebook 3100 2-in-1 Motherboard Replacement, Battery: étape 3, image 1 de 2 Dell Chromebook 3100 2-in-1 Motherboard Replacement, Battery: étape 3, image 2 de 2
    • Disconnect the battery cable from the connector on the system board.
  4. Dell Chromebook 3100 2-in-1 Motherboard Replacement: étape 4, image 1 de 3 Dell Chromebook 3100 2-in-1 Motherboard Replacement: étape 4, image 2 de 3 Dell Chromebook 3100 2-in-1 Motherboard Replacement: étape 4, image 3 de 3
    • Using a Phillips #1 screwdriver, remove the three 4 mm screws that secure the battery.
    • Remove the adhesive tape that secures the battery in place.
  5. Dell Chromebook 3100 2-in-1 Motherboard Replacement: étape 5, image 1 de 2 Dell Chromebook 3100 2-in-1 Motherboard Replacement: étape 5, image 2 de 2
    • Carefully remove the battery from the device.
  6. Dell Chromebook 3100 2-in-1 Motherboard Replacement, Speaker: étape 6, image 1 de 2 Dell Chromebook 3100 2-in-1 Motherboard Replacement, Speaker: étape 6, image 2 de 2
    • Remove adhesive tape that secures the speaker cable.
    • Disconnect the speaker cable from the connector on the system board.
  7. Dell Chromebook 3100 2-in-1 Motherboard Replacement: étape 7, image 1 de 2 Dell Chromebook 3100 2-in-1 Motherboard Replacement: étape 7, image 2 de 2
    • Remove the speaker cable from the retention clips.
  8. Dell Chromebook 3100 2-in-1 Motherboard Replacement: étape 8, image 1 de 2 Dell Chromebook 3100 2-in-1 Motherboard Replacement: étape 8, image 2 de 2
    • Lift and remove the speakers from the device.
  9. Dell Chromebook 3100 2-in-1 Motherboard Replacement, Motherboard: étape 9, image 1 de 3 Dell Chromebook 3100 2-in-1 Motherboard Replacement, Motherboard: étape 9, image 2 de 3 Dell Chromebook 3100 2-in-1 Motherboard Replacement, Motherboard: étape 9, image 3 de 3
    • Disconnect the keyboard cable.
  10. Dell Chromebook 3100 2-in-1 Motherboard Replacement: étape 10, image 1 de 1
    • Disconnect the two input-output board cables from the motherboard.
  11. Dell Chromebook 3100 2-in-1 Motherboard Replacement: étape 11, image 1 de 2 Dell Chromebook 3100 2-in-1 Motherboard Replacement: étape 11, image 2 de 2
    • Disconnect the touchpad cable.
    • Disconnect the USB Type-C power cable.
  12. Dell Chromebook 3100 2-in-1 Motherboard Replacement: étape 12, image 1 de 3 Dell Chromebook 3100 2-in-1 Motherboard Replacement: étape 12, image 2 de 3 Dell Chromebook 3100 2-in-1 Motherboard Replacement: étape 12, image 3 de 3
    • Remove the single 3 mm screw that secures the WLAN bracket to the system board using a Phillips #1 screwdriver.
    • Lift the WLAN bracket from the system board.
    • After lifting the bracket, carefully unplug the two coaxial cables.
  13. Dell Chromebook 3100 2-in-1 Motherboard Replacement: étape 13, image 1 de 1
    • Remove the single 4 mm screw that secures the eDP bracket to the motherboard using a Phillips #1 screwdriver.
    • Remove the eDP bracket.
  14. Dell Chromebook 3100 2-in-1 Motherboard Replacement: étape 14, image 1 de 2 Dell Chromebook 3100 2-in-1 Motherboard Replacement: étape 14, image 2 de 2
    • Disconnect the display cable from the motherboard by using a plastic opening pick.
  15. Dell Chromebook 3100 2-in-1 Motherboard Replacement: étape 15, image 1 de 3 Dell Chromebook 3100 2-in-1 Motherboard Replacement: étape 15, image 2 de 3 Dell Chromebook 3100 2-in-1 Motherboard Replacement: étape 15, image 3 de 3
    • Remove the five 4 mm screws that secure the motherboard using a Phillips #1 screwdriver.
  16. Dell Chromebook 3100 2-in-1 Motherboard Replacement: étape 16, image 1 de 2 Dell Chromebook 3100 2-in-1 Motherboard Replacement: étape 16, image 2 de 2
    • Lift and remove the motherboard from the computer.
6 autres ont terminé cette réparation.
Muhammad Ali
Membre depuis le 09/02/21
352 Réputation
2 tutoriels rédigés
Équipe
Gateway, Team 1-1, Pee Fall 2021 Membre de l'équipe Gateway, Team 1-1, Pee Fall 2021
GCC-PEE-F21S1G1
5 membres
5 tutoriels rédigés
Un commentaire
Any idea how to use the USB repair shim? Dell's guide didn't help
Josie - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 32
30 derniers jours : 73
Total : 2,299
