Aller au contenu principal
Dell Chromebook 3100 2-in-1 Speaker Replacement
Ce dont vous avez besoin
  1. Dell Chromebook 3100 2-in-1 Speaker Replacement, Back Cover: étape 1, image 1 de 2 Dell Chromebook 3100 2-in-1 Speaker Replacement, Back Cover: étape 1, image 2 de 2
    • Using a Phillips #1 screwdriver, remove all nine of the 5 mm screws from the back cover.
  2. Dell Chromebook 3100 2-in-1 Speaker Replacement: étape 2, image 1 de 2 Dell Chromebook 3100 2-in-1 Speaker Replacement: étape 2, image 2 de 2
    • Use the opening tool to pry the back cover off of the device.
  3. Dell Chromebook 3100 2-in-1 Speaker Replacement, Battery: étape 3, image 1 de 2 Dell Chromebook 3100 2-in-1 Speaker Replacement, Battery: étape 3, image 2 de 2
    • Disconnect the battery cable from the connector on the system board.
  4. Dell Chromebook 3100 2-in-1 Speaker Replacement: étape 4, image 1 de 3 Dell Chromebook 3100 2-in-1 Speaker Replacement: étape 4, image 2 de 3 Dell Chromebook 3100 2-in-1 Speaker Replacement: étape 4, image 3 de 3
    • Using a Phillips #1 screwdriver, remove the three 4 mm screws that secure the battery.
    • Remove the adhesive tape that secures the battery in place.
  5. Dell Chromebook 3100 2-in-1 Speaker Replacement: étape 5, image 1 de 2 Dell Chromebook 3100 2-in-1 Speaker Replacement: étape 5, image 2 de 2
    • Carefully remove the battery from the device.
  6. Dell Chromebook 3100 2-in-1 Speaker Replacement, Speaker: étape 6, image 1 de 2 Dell Chromebook 3100 2-in-1 Speaker Replacement, Speaker: étape 6, image 2 de 2
    • Remove adhesive tape that secures the speaker cable.
    • Disconnect the speaker cable from the connector on the system board.
  7. Dell Chromebook 3100 2-in-1 Speaker Replacement: étape 7, image 1 de 2 Dell Chromebook 3100 2-in-1 Speaker Replacement: étape 7, image 2 de 2
    • Remove the speaker cable from the retention clips.
  8. Dell Chromebook 3100 2-in-1 Speaker Replacement: étape 8, image 1 de 2 Dell Chromebook 3100 2-in-1 Speaker Replacement: étape 8, image 2 de 2
    • Lift and remove the speakers from the device.
M Ali
Membre depuis le 11/03/21
313 Réputation
2 tutoriels rédigés
Équipe
Gateway, Team 1-1, Pee Fall 2021 Membre de l'équipe Gateway, Team 1-1, Pee Fall 2021
GCC-PEE-F21S1G1
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 26
30 derniers jours : 32
Total : 350
