Aller au contenu principal
Dell Chromebook 3100 2-in-1 Webcam Replacement
Ce dont vous avez besoin
  1. Dell Chromebook 3100 2-in-1 Webcam Replacement, Webcam: étape 1, image 1 de 1
    • Using a Phillips screw driver (PH1) remove the 9 (M2.5x4) screws holding the back cover
  2. Dell Chromebook 3100 2-in-1 Webcam Replacement: étape 2, image 1 de 1
    • Using a jimmy and remove the plastic covering to reveal internal hardware.
  3. Dell Chromebook 3100 2-in-1 Webcam Replacement: étape 3, image 1 de 1
    • Unplug the battery from the motherboard by pulling gently.
  4. Dell Chromebook 3100 2-in-1 Webcam Replacement: étape 4, image 1 de 1
    • Remove the single screw (M2x3).
    • Remove the bracket over the Wi-Fi and camera plugs.
  5. Dell Chromebook 3100 2-in-1 Webcam Replacement: étape 5, image 1 de 1
    • Unplug the now revealed camera and Wi-Fi antennas by gently pulling.
  6. Dell Chromebook 3100 2-in-1 Webcam Replacement: étape 6, image 1 de 1
    • Remove the single screw (M2x4).
    • Remove the bracket over the display cable.
  7. Dell Chromebook 3100 2-in-1 Webcam Replacement: étape 7, image 1 de 1
    • Lift the black tab and gently pull on the display cable to disconnect it.
  8. Dell Chromebook 3100 2-in-1 Webcam Replacement: étape 8, image 1 de 2 Dell Chromebook 3100 2-in-1 Webcam Replacement: étape 8, image 2 de 2
    • Remove the 6 screws (M2.5x5) holding the hinges on both ends.
    • When both brackets are free, separte the screen from the computer screen from the bottom section.
  9. Dell Chromebook 3100 2-in-1 Webcam Replacement: étape 9, image 1 de 1
    • Use a jimmy to pry between the 2 layers of the now disconnected display.
  10. Dell Chromebook 3100 2-in-1 Webcam Replacement: étape 10, image 1 de 1
    • Unplug the webcam by gently pulling on the cable shown.
  11. Dell Chromebook 3100 2-in-1 Webcam Replacement: étape 11, image 1 de 2 Dell Chromebook 3100 2-in-1 Webcam Replacement: étape 11, image 2 de 2
    • Use a jimmy to pry up the webcam, which is to then be removed.
ot moya
Membre depuis le 11/09/23
481 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team 3-2, Harley Fall 2023 Membre de l'équipe IUPUI, Team 3-2, Harley Fall 2023
IUPUI-HARLEY-F23S3G2
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 40
Total : 312
