Aller au contenu principal
Dell Chromebook 3110 Battery Replacement
Ce dont vous avez besoin
  1. Dell Chromebook 3110 Battery Replacement, Battery: étape 1, image 1 de 1
    • Set the laptop upside down on a clean work space.
  2. Dell Chromebook 3110 Battery Replacement: étape 2, image 1 de 1
    • Remove nine 4 mm screws from the back cover of the laptop using a Phillips #00 screwdriver.
  3. Dell Chromebook 3110 Battery Replacement: étape 3, image 1 de 1
    • Using an opening pick and a plastic opening tool, begin to separate the back cover from the laptop.
    • Using your hands, fully remove the back cover.
  4. Dell Chromebook 3110 Battery Replacement: étape 4, image 1 de 1
    • Unplug the battery from the motherboard by gently pulling on the cable header from the motherboard toward the battery.
    • Using the Phillips #0 screwdriver, remove the three screws from the battery.
  5. Dell Chromebook 3110 Battery Replacement: étape 5, image 1 de 1
    • Carefully lift the battery out of the laptop.
To reassemble your device, follow these instructions in reverse order. For optimal performance, calibrate your newly installed battery after completing this guide.
3 autres ont terminé cette réparation.
Anna K Tomko
Membre depuis le 02/24/23
166 Réputation
1 tutoriel rédigé
Équipe
Marist, Team 1-6, Chaterdon Spring 2023 Membre de l'équipe Marist, Team 1-6, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G6
2 membres
2 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 16
30 derniers jours : 55
Total : 968
