Aller au contenu principal
Dell Chromebook 3180 Charging Port Replacement
Ce dont vous avez besoin
  1. Dell Chromebook 3180 Charging Port Replacement, Remove Bottom Cover / Shell: étape 1, image 1 de 2 Dell Chromebook 3180 Charging Port Replacement, Remove Bottom Cover / Shell: étape 1, image 2 de 2
    • Remove the 7 screws from the back cover with a Phillips #0 screwdriver
    • Once all 7 screws have been removed, you can start to pry apart the back cover with your Plastic Blade or your fingers. (See pic)
    • Using a Phillips #0, remove the 2 screws from the right side hinge.
    • Lift the chromebook base in order to force the hinge in an upward position. This will provide you enough room to remove the charging port.
    • Remove the 2 charging port screws
    • Unplug the charging port connector from the Motherboard
    • Disconnect the charging port connector from the motherboard.
    • Replace the charging port if needed by connecting the new charging port connector to the motherboard.
    • Using a Phillips#0, replace the 2 charging port screws.
    • Reset the right side hinge back into place by pressing down so the hinge is flush against the chromebook base.
    • Secure with the 2 screws using your phillips #0.
  2. Dell Chromebook 3180 Charging Port Replacement, Replace Bottom Cover: étape 5, image 1 de 1
    • Secure all 7 screws with a Phillips #0
4 autres ont terminé cette réparation.
Jon
Membre depuis le 08/18/13
3 921 Réputation
22 tutoriels rédigés
Un commentaire
Hey Party Person, nice job. I believe you might be the greatest tech to ever hold a screw driver. This song is for you https://youtu.be/ItWIYcD6jas
foshizol - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 12
Total : 1,070
