Aller au contenu principal
Dell Chromebook 3180 LCD Replacement
Ce dont vous avez besoin
    • Open the chromebook until its completely flat on the table
    • Remove both the left and right hinge caps
    • Remove a total of 4 screws. One in each corner.
    • Use a plastic pry tool or blade and start in the top left corner or first left plastic ridge.
    • Lift up the LCD screen from within the LCD assembly frame.
    • On the back of the LCD screen, remove the tape and LCD connector
    • Attach the LCD connector
    • re-apply the tape to the LCD connector
    • Set the new LCD screen into the LCD assembly frame while matching up the screw ports in each corner
    • When installing the LCD bezel, look for the plastic hinge outlines on each side and match them up with the metal hinges on the chromebook.
    • Snap the LCD bezel in place until it is flush with the entire LCD assembly
Jon
Membre depuis le 08/18/13
3 921 Réputation
22 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 11
Total : 798
