Aller au contenu principal
Dell E193FPc Display Bezel Replacement
Ce dont vous avez besoin
  1. Dell E193FPc Display Bezel Replacement, Stand: étape 1, image 1 de 1
    • Lay the monitor screen-down so the back screws are exposed.
    • Remove the four 11.9 mm Phillips #2 screws securing the stand to the back of the monitor.
  2. Dell E193FPc Display Bezel Replacement: étape 2, image 1 de 1
    • Gently lift and pull away the stand at a slight angle away from the monitor.
  3. Dell E193FPc Display Bezel Replacement, Display Bezel: étape 3, image 1 de 2 Dell E193FPc Display Bezel Replacement, Display Bezel: étape 3, image 2 de 2
    • Locate the two holes on the bottom of the monitor.
    • Insert a plastic opening tool or spudger into the holes and gently pry the plastic apart along the groove.
    • This task is much easier if two people pry simultaneously at each hole.
    • Continue prying along the entire edge of the monitor.
  4. Dell E193FPc Display Bezel Replacement: étape 4, image 1 de 2 Dell E193FPc Display Bezel Replacement: étape 4, image 2 de 2
    • When finished prying, the plastic will partially fall away from the rest of the monitor.
    • Do not try to fully remove the front frame yet. The frame is still attached to the buttons.
    • While holding the frames together, carefully flip the monitor over so it faces screen down.
    • Gently lift and remove remove the rear case from the monitor.
  5. Dell E193FPc Display Bezel Replacement: étape 5, image 1 de 3 Dell E193FPc Display Bezel Replacement: étape 5, image 2 de 3 Dell E193FPc Display Bezel Replacement: étape 5, image 3 de 3
    • Locate the green interface button board.
    • Remove the three 9.71 mm Phillips #2 screws holding the interface button board to the display bezel.
    • Lift the monitor interior away from the front cover.
5 autres ont terminé cette réparation.
Mackenzie Keane
Membre depuis le 10/04/11
514 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 5-36, Amido Fall 2011 Membre de l'équipe Cal Poly, Team 5-36, Amido Fall 2011
CPSU-AMIDO-F11S5G36
4 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 23
Total : 4,293
