Aller au contenu principal
Dell G15-5511 Gaming RAM Replacement
Ce dont vous avez besoin
  1. Dell G15-5511 Gaming RAM Replacement, Unfasten the back cover: étape 1, image 1 de 2 Dell G15-5511 Gaming RAM Replacement, Unfasten the back cover: étape 1, image 2 de 2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Phillips #1 screwdriver to remove the four 6.8 mm-long screws that secure the cover.
    • Use a Phillips #1 screwdriver to loosen the four captive screws.
  2. Dell G15-5511 Gaming RAM Replacement, Unclip the front corners: étape 2, image 1 de 2 Dell G15-5511 Gaming RAM Replacement, Unclip the front corners: étape 2, image 2 de 2
    • Insert an opening pick between the bottom-left corner of the back cover and the chassis.
    • Pry up to release the clips securing the back cover.
    • You'll hear a click whenever a clip is released.
  3. Dell G15-5511 Gaming RAM Replacement: étape 3, image 1 de 2 Dell G15-5511 Gaming RAM Replacement: étape 3, image 2 de 2
    • Insert your opening pick again between the bottom-right corner of the back cover and the chassis.
    • Pry up to release the remaining clips securing the back cover.
  4. Dell G15-5511 Gaming RAM Replacement, Remove the back cover: étape 4, image 1 de 3 Dell G15-5511 Gaming RAM Replacement, Remove the back cover: étape 4, image 2 de 3 Dell G15-5511 Gaming RAM Replacement, Remove the back cover: étape 4, image 3 de 3
    • Grip the front of the back cover and lift it away from the laptop.
    • Pull the back cover towards you to disconnect the clips along the top of the back cover.
    • Remove the back cover.
  5. Dell G15-5511 Gaming RAM Replacement, RAM: étape 5, image 1 de 3 Dell G15-5511 Gaming RAM Replacement, RAM: étape 5, image 2 de 3 Dell G15-5511 Gaming RAM Replacement, RAM: étape 5, image 3 de 3
    • Locate the component in the circle area, the battery connector on the motherboard.
    • Carefully grasp the connector by its side and pull it away from the mother board.
    • Do not apply excessive force since it could damage the connector or the socket.
  6. Dell G15-5511 Gaming RAM Replacement: étape 6, image 1 de 3 Dell G15-5511 Gaming RAM Replacement: étape 6, image 2 de 3 Dell G15-5511 Gaming RAM Replacement: étape 6, image 3 de 3
    • Locate the two RAM slots highlighted by the red rectangles.
    • Locate the metal retaining clip outward, as highlighted by the red rectangles.
    • Carefully grasp the metal retain clips and pull them away from the RAM slot.
  7. Dell G15-5511 Gaming RAM Replacement: étape 7, image 1 de 3 Dell G15-5511 Gaming RAM Replacement: étape 7, image 2 de 3 Dell G15-5511 Gaming RAM Replacement: étape 7, image 3 de 3
    • Once the clips are released, carefully pull the module out of the slot.
    • When installing the new RAM, align the notches on the RAM module with the gap in the slot.
    • Push down the RAM until the metal retaining clip snaps into place, retaining the RAM.
    • If you have a second RAM that you want to be replaced, simply repeat the Step 2 and Step 3.
  8. Dell G15-5511 Gaming RAM Replacement: étape 8, image 1 de 3 Dell G15-5511 Gaming RAM Replacement: étape 8, image 2 de 3 Dell G15-5511 Gaming RAM Replacement: étape 8, image 3 de 3
    • Reconnect the Battery to the motherboard.
    • Using a screwdriver to secure the battery connector, carefully push forward the top part of the battery connector.
Ligne d'arrivée
2 autres ont terminé cette réparation.
Hang Bao
Membre depuis le 10/23/23
136 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 3-72, Briggs Fall 2023 Membre de l'équipe CSU Los Angeles, Team 3-72, Briggs Fall 2023
CSULA-BRIGGS-F23S3G72
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 14
30 derniers jours : 48
Total : 357
