Aller au contenu principal
Dell Inpiron 3542 Motherboard Replacement
Ce dont vous avez besoin
  1. Dell Inpiron 3542 Motherboard  Replacement, Motherboard: étape 1, image 1 de 2 Dell Inpiron 3542 Motherboard  Replacement, Motherboard: étape 1, image 2 de 2
    • Slide the latches on both sides of the laptop outward to unlock the battery.
    • Remove the battery from the computer.
    • Replacing a motherboard can lead to data loss. Make sure to backup any important data on the laptop before replacing the motherboard.
  2. Dell Inpiron 3542 Motherboard  Replacement: étape 2, image 1 de 2 Dell Inpiron 3542 Motherboard  Replacement: étape 2, image 2 de 2
    • Remove the screw. (1 x M2 x 3mm)
    • Slide down the access door and remove it.
  3. Dell Inpiron 3542 Motherboard  Replacement: étape 3, image 1 de 3 Dell Inpiron 3542 Motherboard  Replacement: étape 3, image 2 de 3 Dell Inpiron 3542 Motherboard  Replacement: étape 3, image 3 de 3
    • Move the hard drive to the open area and remove it.
  4. Dell Inpiron 3542 Motherboard  Replacement: étape 4, image 1 de 3 Dell Inpiron 3542 Motherboard  Replacement: étape 4, image 2 de 3 Dell Inpiron 3542 Motherboard  Replacement: étape 4, image 3 de 3
    • Unplug the black and white antenna cables from the wireless card.
    • Remove the wireless card from the laptop.
  5. Dell Inpiron 3542 Motherboard  Replacement: étape 5, image 1 de 2 Dell Inpiron 3542 Motherboard  Replacement: étape 5, image 2 de 2
    • Remove all screws from the bottom of the laptop. (10 x M2.5 x 5mm)
    • Turn over the laptop and open it.
  6. Dell Inpiron 3542 Motherboard  Replacement: étape 6, image 1 de 2 Dell Inpiron 3542 Motherboard  Replacement: étape 6, image 2 de 2
    • Use the plastic prying device to release the keyboard. Avoid from using excessive force to prevent damages.
    • Lift the keyboard.
    • Unplug the cable connecting the keyboard to the laptop.
    • Remove the keyboard.
  7. Dell Inpiron 3542 Motherboard  Replacement: étape 7, image 1 de 3 Dell Inpiron 3542 Motherboard  Replacement: étape 7, image 2 de 3 Dell Inpiron 3542 Motherboard  Replacement: étape 7, image 3 de 3
    • Unplug the touch pad cables located on the palm rest.
    • Remove the screws. (3 x M2.5 x 5mm)
  8. Dell Inpiron 3542 Motherboard  Replacement: étape 8, image 1 de 2 Dell Inpiron 3542 Motherboard  Replacement: étape 8, image 2 de 2
    • Carefully unsnap the palm rest from the rest of the laptop.
    • Remove the palm rest.
  9. Dell Inpiron 3542 Motherboard  Replacement: étape 9, image 1 de 1
    • Unplug the cable that connects to the motherboard.
    • Remove the DC jack from the laptop.
  10. Dell Inpiron 3542 Motherboard  Replacement: étape 10, image 1 de 1
    • Loosen the cables on the antenna.
  11. Dell Inpiron 3542 Motherboard  Replacement: étape 11, image 1 de 2 Dell Inpiron 3542 Motherboard  Replacement: étape 11, image 2 de 2
    • Remove the screws. (1 x M2 x 3mm)
    • Unplug the circuit board from the rest of the computer.
  12. Dell Inpiron 3542 Motherboard  Replacement: étape 12, image 1 de 1
    • Loosen the tape on the left side of the laptop.
    • Unplug the display cable.
  13. Dell Inpiron 3542 Motherboard  Replacement: étape 13, image 1 de 2 Dell Inpiron 3542 Motherboard  Replacement: étape 13, image 2 de 2
    • Unplug the cable on the bottom part of the mother board.
    • Remove the cable on the right side of the motherboard. (3x M2.5 x 5mm)
    • Remove the motherboard from the laptop.
To reassemble your device, follow these instructions in reverse order. Congratulations on replacing the Motherboard on your Dell Inpiron 3542.
5 autres ont terminé cette réparation.
Rachel lindsey
Membre depuis le 03/21/17
733 Réputation
5 tutoriels rédigés
Équipe
Texas Tech, Team S46-G1, Bennett Spring 2017 Membre de l'équipe Texas Tech, Team S46-G1, Bennett Spring 2017
TTU-BENNETT-S17S46G1
3 membres
7 tutoriels rédigés
Un commentaire
Anyone know where I can purchase a board for a Dell Inspiron 3542 in the UK?
Darrell Haslam - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 18
30 derniers jours : 22
Total : 3,739
