Aller au contenu principal
Dell Inspirion 15z-5523 Hard Disk Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspirion 15z-5523 Hard Disk Drive Replacement, Hard Disk Drive (HDD): étape 1, image 1 de 1
    • Pop out the rubber pieces and unscrew the 7 screws on the bottom of the computer.
    • Open the RAM door in the center remove the hidden screw labeled "KB" just above the RAM sticks.
  2. Dell Inspirion 15z-5523 Hard Disk Drive Replacement: étape 2, image 1 de 1
    • Using a nylon spudger, push the retaining clips away from the keyboard - there are five along the top row, and two on each side. You can carefully pull the keyboard away from each clip when it's released. The bottom edge of the keyboard will just pull away.
  3. Dell Inspirion 15z-5523 Hard Disk Drive Replacement: étape 3, image 1 de 2 Dell Inspirion 15z-5523 Hard Disk Drive Replacement: étape 3, image 2 de 2
    • There are two ribbon cables securing the keyboard - data and backlight power. Each ribbon connector must be released by flipping the black retainer up with a fingernail or nylon Uspudger before pulling out the ribbon.
    • First flip up the black retainer on the smaller connector. Slide the cable up and out of the connector.
    • Secondly, flip the black connector up on the larger connector. Slide the cable straight out of the connector, parallel to the case.
    • Remove the keyboard from the case.
  4. Dell Inspirion 15z-5523 Hard Disk Drive Replacement: étape 4, image 1 de 2 Dell Inspirion 15z-5523 Hard Disk Drive Replacement: étape 4, image 2 de 2
    • Unscrew the surface under the keyboard and remove top plate from the base.
  5. Dell Inspirion 15z-5523 Hard Disk Drive Replacement: étape 5, image 1 de 2 Dell Inspirion 15z-5523 Hard Disk Drive Replacement: étape 5, image 2 de 2
    • Take the battery out by unscrewing the 5 screws and pulling straight off.
  6. Dell Inspirion 15z-5523 Hard Disk Drive Replacement: étape 6, image 1 de 1
    • Remove the hard drive.
3 autres ont terminé cette réparation.
Christian Chavez
Membre depuis le 01/23/18
729 Réputation
5 tutoriels rédigés
0 Guide Comments
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 22
Total : 3,572
